Location: South AL/// Z06 Fest Participant I, II, III, IV, V, VI, VII, VIII
383 C5 Z06 vs. 427 C5 Z06
I was in 3rd @ 45 mph on the first pull, way down on the tach... should've been in 2nd. On the 2nd run I ran 5th into the limiter which is around 155-157with the MN12/3.90 combo.
Cool vids Dan! 2nd run was alot more representative of what your car can do when that 383 is in the power band! I bet the other guy was pretty surprised! Good job!
Jimbo
'03 EB/mod blue, LME/V-Max 416, AFR 225's, Comp Custom cam from Pete at V-Max, 3" custom exhaust and lots of attitude! 10.79@128.32 Z06 Fest member III, IV, V, VI, VII, VIII and Winterfests 1, 2 & 3. 543rwhp/493rwtq, all motor!
2000 Silverado, Best 1.54 sixty, 402 Stroker NA, 410 gears, Street cam, heads and Fast by Pete Incaudo 11.17 ET & 119 mph
Nice run. Probably th ebest night tiume video I have seen so far. very clear and not dark as most are.
Re: 383 C5 Z06 vs. 427 C5 Z06
His car is sort of a sleeper if you will... no lopey idle and factory titanium axle-back. It has a ram air box and I'm thinking that has to help him at those speeds. He was surprised by my car and asked if I was spraying on the 2nd run. Nope, we just started right in the sweet spot
'04 MS/Blk - Z06Fest IV, V, VI, VII & VIII - WinterFest I "Bus Driver"
