Go Back   Z06Vette.com - Corvette Z06 Forum > Other Z06 Topics > The Street
Old 07-10-2007, 07:39 PM   #1 (permalink)
El Calor's Avatar
Send a message via AIM to El Calor
What A 1038hp Looks Like!
El Calor is offline   Reply With Quote
Old 07-10-2007, 07:42 PM   #2 (permalink)
YumaZ06's Avatar
Location: Yuma, Az. ?????? Z06 Fest IV, V and Winterfest 1 & 2
Re: What A 1038hp Looks Like!
Looks like he was melting his tires! Awesome.
2004 MS/BLK
NCM#31853
"I know I'm in my own little world, but it's ok, they know me here."
Old 07-10-2007, 07:44 PM   #3 (permalink)
El Calor's Avatar
Yeah that's just on a dyno, don't worry about that
Old 07-10-2007, 07:46 PM   #4 (permalink)
YumaZ06's Avatar
That much HP with spinning the tires is awesome.
Old 07-10-2007, 08:46 PM   #5 (permalink)
Location: Edgewater, MD Z06 Fests 2,3,4,5,6, Ocean & WinterFest 1&2
YEEEEEEEhaw!!!! Hold onto your hat!!
That much power is very !!!!
NCM # 23306 Fest Member 2, 3, 4, 5, 6, Ocean & WinterFest 1 & 2
Old 07-11-2007, 05:56 AM   #6 (permalink)
MSiska's Avatar
Holy Moly!! That was way cool!!
Old 07-11-2007, 06:03 AM   #7 (permalink)
Morzoff's Avatar
That was Awesome
Tuned in Speed Density by Synergy Motorsports
R.I.P Dad
Morzoff is offline   Reply With Quote
Old 07-11-2007, 06:54 AM   #8 (permalink)
Maybe post up some details if you can......
just curious of the engine build...
Old 07-11-2007, 07:27 AM   #9 (permalink)
G-Z06's Avatar
Send a message via AIM to G-Z06
LPE's TT C6. They featured that car in the motortrend shoot out.
Sickness!
Daytona Sunset Orange with ebony interior
ZO6 Factory body panels added to allow giant 285/35ZR19 tires front & 335/30ZR20 rear
Only 1,000 miles on the vehicle
This is a one off prototype car that has not be duplicated and holds the record for fastest
standing mile street Corvette in the world.
1,038 rear wheel horsepower with C16 fuel. This was not the maximum power but only LPE's target for this shoot out, it has much more potential. The electronic adjustable boost controller will allow 93 octane fuel on low boost.
Lingenfelter standard 427 TT Includes:
* GM 7.0L aluminum block
* 4340 forged steel crankshaft
* Custom forged aluminum pistons
* Forged steel connecting rods
* Computer balanced rotating assembly
* LPE CNC-porting and hand polishing of cylinder heads
* 2.02-inch intake/1.57-inch exhaust valves
* Custom double valve springs with titanium retainers
* LPE hydraulic roller camshaft and lifters
* Two Garret hybrid GT-series ball-bearing turbochargers
* High efficiency liquid-to-air charge cooler
* High efficiency liquid-to-air heat exchanger, pump, and coolant tank
* Custom molded silicone air ducts
* Custom stainless-steel exhaust manifolds
* Custom stainless-steel turbo outlet adapters
* LPE belt-driven turbocharger scavenge pump and oil reservoir
* Conical air filters, heat shields, and stainless-steel clamps
* LPE MAF sensor
* High capacity fuel system
* Oversized fuel injectors
* LPE rear mount battery system
* Corsa 2.5-inch diameter stainless-steel cat-back dual exhaust system
* Professional installation, tuning, and dyno testing
Package price as shown $52,995.00
Shoot out version includes these
changes and additions
* Custom Moldex billet steel crankshaft
* Oliver Billet steel connecting rods
* Heavy-duty timing chain set
* FAST 90 MM intake manifold
* Upgraded fuel injectors & support electronics
* Secondary fuel pump system
* High-flow fuel rails with adjustable fuel pressure regulator
* Custom Corsa 3-inch diameter stainless-steel exhaust system
* TiaL blow-off valves
* TiaL external waste gates
* LPE custom dry sump oil system
* Custom GT35R ball-bearing turbochargers -special water cooled turbos
* Custom stainless-steel exhaust manifolds and outlets
* Higher capacity intercooler with remote rear-mounted coolant tank
* Electronic boost controller
* Transmission overhaul including H-D main shaft and gear sets
* 3.15:1 rear differential gear set
* Heavy-duty differential output shafts
* McLeod dual-disk clutch with sintered iron disks
* Clutch scattershield with transmission safety blanket
* 6-point roll bar with removable side door bars
* Recaro racing seats - driver & passenger
* 5-point racing seat belt system - driver & passenger
* Boost gauge with gauge pod
* Shift light
* Fire extinguisher
* Video camera mount
1,100 HP Upgrades $94,500.00
Additional Vehicle Upgrades
* DRM / Bilstein coil-over shocks / springs
* Special anti-roll bar end links
* HRE 844R 19x10-inch (front) and 20x12.5-inch (rear) forged aluminum wheels
* Michelin Pilot Sport 2 285/35ZR19 (front) and 335/30ZR20 (rear) tires
* Chevrolet Z06 front and rear fenders, front fascia, painting, installation
* Labor to modify vehicle for oversized wheels/tires
* Brembo 4-piston calipers, 14-inch diameter 2-piece, cross-drilled rotors, heavy-duty brake pads, stainless-steel brake lines (front and rear)
* Innovative Motorsports air/fuel meter and data acquisition system
Additional upgrades $29,935.00
Total price of vehicle modifications $177,430.00
Price of vehicle $48,430.00
Total price of vehicle as tested $225,860.00
For Sale $130,000.00
GHOST MACHINE
F1 IDLE VIDEO/DYNO VIDEO/RACING CAMEO'S CAR
G-Z06 is offline   Reply With Quote
Old 07-11-2007, 08:00 AM   #10 (permalink)
Hmmm...just a little depreciation there.
Don Benson is offline   Reply With Quote
Old 07-11-2007, 11:57 AM   #11 (permalink)
The owner sold the car pretty soon afterwards, if I remember correctly, he got tired of driving what basically amounted to an ICBM.
He had a blower viper which also went up for sale, think he's doing the lamborghini thing now.
Old 07-21-2007, 06:52 PM   #12 (permalink)
Millenium Z06's Avatar
That car's a punk heres what 1077 RWHP looks like:
http://www.youtube.com/watch?v=hsjx0LgtoDA
2003 Millenium Yellow Z06
Millenium Z06 is offline   Reply With Quote
Old 07-21-2007, 07:12 PM   #13 (permalink)
pugads650 is offline   Reply With Quote
Old 07-22-2007, 03:20 AM   #14 (permalink)
That's sick HP!
02 MY Z06 440RWHP/402RWTQ - Sold
08 BLK/BLK Z06 - Bone Stock
Old 07-23-2007, 11:28 AM   #15 (permalink)
Niiice.
Rate This Thread:
HTML code is On
