Anyone out there who has the $23k LPE Stage 1 TT kit on their car been to the track?
Anyone seen one or know of someone who has been to the track?
Just looking for some ET/MPH comparisons to file away in my "database".
Thanks!
'06 300C SRT8
That _is_ impressive! IanZ06's car just got done here in Dallas at 21CMC and he reported 513rwhp, but I'm sure that is low boost/pump gas. 11psi with an otherwise stock 10.5:1 CR, would have to have race fuel.
No matter, that is excellent, and shows the potential of the system.
Wonder what it would do if you got the new AFR 205 heads (better than CNC ported LS6 heads) to be released in Jan/Feb? And used the 76cc chambered ones which lower the CR! 10-11psi might be ok on _pump_ gas. Hello!
I do my own heads , I been porting heads since 1973 when I built my first 68 L88 Camaro which ran 9.95 @ 136 MPH and I was all of 18 years old , I' ve been racing ever since.
I did the heads on my wifes 99 A4 coupe (stock CAM, she hates a car that shakes at idle. lol) and put a blackwing on, 3.42 rear, 2400 stall , ported the throttle body and the results were 11.99 @ 116.15 on BFG DR's
Wes, My friend got one of the first stage 1 Z06's in 2001. There are big differances depending on the exaust system and if your running cats. But as his memory, the numbers with cats it was 11.4 126.7, 01's had a cat problem, without cats it went 132 for him. John used his car for one of the shootouts and ran 134 back then. Only john knows what he did to pick it up... After adding the boost controler it went 10.20 with a best of 141. Hope that helps. Ric
really... thats impressive i think thats good blue print for me
Thanks for the info. 132+ is impressive. That's easily 530+rwhp and good average HP for it to be running that fast. From what I understand, many guys are getting the adjustable boost controller to bump it up when they run race fuel.
