Old 12-25-2004, 10:19 AM   #1 (permalink)
275/35/18 and 335/30/18 Hoosiers 18x10.5
Waiting on the CCWs. Sold my 17's and only have 4 rear 18's left except for my street tire set-up. Santa is running late so I am looking for a good tire set-up for an upcoming track date.
I have the DRM ducts and rear stock ducts with the car lowered on factory bolts.
Will this Hoosier combo work without issues on the track or do you have a better suggestion?
Hoosier
Front 275/35/18 on the 18x10.5's( stock rears )
Rear 335/30/18 on the 18x10.5's ( stock rears )
I hear the 335's will squeeze on the 18 x 10.5's. Don't know if they will rub the rear ducts though.
I really don't want to remove either set of ducts so I am looking for a CONFIRMED set-up for the 18's all around. I don't want to mess with the ride height/alignment at the track to make it fit. Also have T1 bars all around.
Been running the GSCS in stock sizes with good luck. Is the Hoosier still the best choice for a track only tire?. Any help would be great.
Old 12-25-2004, 07:58 PM   #2 (permalink)
Why not 305/30/18's all around?
From my thread:
Originally Posted by sleeper02Z06
I run the 18x10.5 rear stock rims on the front with 305/30 hoosiers for HPDE's and I have the DRM ducts. You will only get about 3/4 turn on the steering wheel with this setup, fine for the track but not for the street IMHO. You simply have to be careful in the pits. If it were not for the DRMs, this setup would be "streetable" with no clearance issues. Hope this helps.
Joe
2003 MY Z06-LS2 408, Dart 225, Crower 238/246 .622/.609 112+4, Vararam, LG Pro Headers, Ron Davis ROC, T1 Bars, DRM Coilovers, Mov'it BBK, CCW Corsairs, Sparco Evo2/Hardbar.
Dr Chill is offline   Reply With Quote
Old 12-26-2004, 12:02 PM   #3 (permalink)
I was trying to keep the rake about the same. If the 305's enough for track use that's a bunch of tire up front .
My thoughts were
275/ 35 = 25.2 dia - width 11.2
305/ 30 = 25.6 did - width 12.4
In the front I thought the 275 would give a better turning radius and help keep the rake the same without re-adjusting the ride height/re-align, yada,yada. The diameter diff on the stock tires is about .5. This gets me close at .4.
335 /30 - 25.6 dia - Width 13.5 The question is will the 335's actually fit on the rim with no clearance issues with the rear scoops, wheel wells, etc?
When you run the 305/30 front and 335/30 rear on Rocket Sleds calculator, it actually looks like this would be a better set up. Delta is -.3% vs. -1.7% for the combo of 275/35 & 305/30.
Old 12-26-2004, 06:38 PM   #4 (permalink)
ttt
Will the 335/30/18 fit on the stock rear rim 18x 10.5?
Anyone tried it, I have a third party source that says it fits.
Any clearance issues on rear ducts, fenders etc. lowered on factory bolts.
Happy Holidays !
Old 12-28-2004, 11:52 AM   #5 (permalink)
My BFG DRs are 315 X 30 on the stock rims and there is about 3/4 inch of room to the brake duct and also wheel well at the top from the inside tire surface....(if that makes any sense)
03 EBZ - RPS Clutch Stage III, Alum. Flywheel, LG headers/X Pipe, B&B Singles, Haltech and 315/30 Mickey Thompsons.. 3005Lbs with 1/2 tank of fuel.
stellablu is offline   Reply With Quote
Old 12-30-2004, 08:24 PM   #6 (permalink)
Handling will suck with 335's on 10.5" rims... that's way to wide a tire for that rim width... 12-13" ideal... 11.5" you can get away with.
From Hooiser site:
If you find that your vehicle, or the rules, will not allow a wide enough wheel for the tire you think you would like, consider using a narrower tire. In most cases a properly sized wheel/tire combination will outperform a wider tire on a wheel that is too narrow.
Dreamin is offline   Reply With Quote
Old 12-31-2004, 08:51 PM   #7 (permalink)
Thanks for the info. I heard about a few using this combo with some success. Makes sense if you can't get all the contact patch on the ground.
Old 01-03-2005, 10:05 AM   #8 (permalink)
Redshift's Avatar
I wouldn't go with a 60mm front to rear width delta. Talk about understeer. As it is, I have that setup on my 18's right now, but with Toyo RA1s, and I was not happy with the lowered grip up front (I like to enter corners fast, and could not with 275s up front). I would stick with 305 up front and 335 out back, or 275 up front and 305 in the rear.
Brian A. Marks
Old 01-04-2005, 11:02 PM   #9 (permalink)
DJWorm's Avatar
I recommend using 305/30x18 on 10.5x18 with +0.25" offset in the front.
I recommend using a 315/35x17 on a 11x17 with +0.25" offset in the rear.
AMSOIL Online Store
[WTT] (2) Chrome 18x10.5 OEM Z06 for (2) silver 18x10.5 OEM Z06 5W0P3 Member Sales - Parts & Cars 0 11-15-2006 06:59 PM
Michellin Pilot Sports, 275/40r17 and 335/30r18. 6k miles, good condition Pakisho Member Sales - Parts & Cars 17 05-30-2006 05:24 PM
Do 335/30/18 hoosiers fit in rear on 18x12 CCW's without rubbing Silver Bullet C5 Z06 - Pit Road 10 07-03-2005 11:33 AM
FS: BRAND NEW A3S03 Hoosiers - 275/40-17, 305/30-18 JakeL Member Sales - Parts & Cars 6 04-03-2005 08:22 AM
WTB Toyo ra1 275 and 335 by 18 tires, where to go argon Member Sales - Parts & Cars 10 02-21-2005 09:37 PM
