Old 01-26-2004, 09:46 AM   #1 (permalink)
Anyone running 10's with 100 shot & bolt-ons?
I got to the 1/4-mile track for the first time with my car a few days ago. I have the standard bolt-ons of intake/exhaust (including headers), plus a TNT 100hp shot. I'm running Toyo RA1 335's out back and the car is set up for autocrossing (which is what I mainly do with the car). The tire pressures were 30#, and I know that this is not exactly optimum.
Well, my first time my car kept wanting to roll out of the staging lights (backwards, I think), but the tree went down anyway and I didn't get a great launch. In fact, my 60' time sucked at 2.25 sec. I still pulled out a 11.992 run at 125mph. I figured with practice I could whittle this down to 11.500 or thereabouts with these tires (and hopefully a 60' time of about 1.7 sec). Is my thinking correct with these expectations? Also, with ET Steets, should I be seeing something in the high 10's with practice?
Man 'O War is offline   Reply With Quote
Old 01-26-2004, 10:01 AM   #2 (permalink)
you should get a set of drag radials just to bolt on for the track, I bet that would get those 60 ft times way down...good luck.
1baduramax is offline   Reply With Quote
Old 01-26-2004, 10:09 AM   #3 (permalink)
I would love to do ET Streets, but I'm afraid I'd break something really fast. BTW, some of the H/C guys see high 10's and they have a mere fraction of the torque that I have with my shot. This is why I was thinking that, with practice and ETs, I should see 10's. Just curious if it is possible.
Old 01-26-2004, 10:27 AM   #4 (permalink)
Send a message via AIM to Bad64Vette
Yes, high 10's are very possible. I went 11.02 at 128 on drag radials. I have had some head work and a new cam put in and just haven't been able to get on a good track. I am probably running over to Orlando Speedworld Friday February 6th if you care to join me. We could probably switch the drag radials at the track if you wanted to try them.
Enjoy,
Jimmy
2001 Z06: 160 deg thermostat, lowered 1" inch, Hurst shifter, CarTek 0.567"/0.567" Cam, Heads ported & polished by Champion, LS1 Edit & EFI Live.
1964 Corvette Coupe, Best ET: 7.51 @ 189.87, 632 cid, 10.5" Tire & mufflers, 3520 lbs, 18 deg Big Chief Head, Sheet Metal Tunnel Ram, w/Twin Fogger, 4 Stage Dry Sump. [img]http://www.z06vette.com/gallery/data/500/2822vette2.jpg[img]
Bad64Vette is offline   Reply With Quote
Old 01-26-2004, 10:58 AM   #5 (permalink)
Bad64Vette,
I would love to meet up with you, but I want to try to improve my launches and 60' times before I use ET's or DR's. Last Friday night at Orlando Speedworld was nice with cool, dry air.
Old 01-26-2004, 12:00 PM   #6 (permalink)
I would go with et streets to get your best 60. They flex more than dr so they may be easier on the car also. I have used both. If you get your launch down you will see tens. My car went 10's with cam only(401hp n/a). The launch is the key. You can expect 1.5's at least.
03 Z06 H/C
9.985@138.80
Best 60' 1.41
Old 01-27-2004, 01:35 PM   #7 (permalink)
robz can you please explain how et streets would be easier on the car?! the way i thought about it was... if the wheels dont spin then that pressure has to be put out throught the gears ... and since et streets allow less tire spin there should be a greater force on the transmission and output shafts.. am i correct?
Old 01-27-2004, 05:34 PM   #8 (permalink)
Im not really sure. We'd have to get others opinions. I have been to track rentals where 3 cars broke shafts and they were on bfg dr. All other cars on slicks were fine. Maybe just a coincidence but they definitely flex alot more. Hopefully others will chime in.
Old 01-27-2004, 09:51 PM   #9 (permalink)
Send a message via AIM to brent EB02
robz your right the et streets will be less shock because of the flex you get
02 ZO6 CARTEK 427 600+RWHP 540 RWTQ 10.16@136 MPH
04 GTO STS CARTEK 579 RWHP 639 RWTQ 10.68@129 MPH
10.2@135 MPH VIDEO TURBO GTO 10.68@129 MPH VIDEO
brent EB02 is offline   Reply With Quote
Old 01-28-2004, 06:17 AM   #10 (permalink)
Brent EB02,
Those are nice times in your signature! What rear end gearing are you using with the H/C package?
Old 02-09-2004, 03:39 PM   #11 (permalink)
Send a message via AIM to Want a ZO6
sorry to get off topic but do you have any pics or vids of your 64? 7 sec 1/4 is crazy.
Want a ZO6 is offline   Reply With Quote
Old 02-09-2004, 10:10 PM   #12 (permalink)
Banned
Send a message via AIM to kumar75150
Ya I also used to think drag radials would be easier on the rear that et streets.
WRONG
kumar75150 is offline   Reply With Quote
Old 02-10-2004, 05:57 AM   #13 (permalink)
Want A Z06,
Yes, I have some videos and pics I can post but how the hell do I attach them to this post.
Jimmy
Old 02-10-2004, 12:20 PM   #14 (permalink)
WRONG
so why would anyone buy BFGs if ETs hook better and are easier on the car?(i am not disagreeing i just want to see the logic behind it)
Old 02-10-2004, 01:00 PM   #15 (permalink)
1)drag radials are cheaper because they will fit on your stock rims and most serious guys buy skinnies up front when getting slicks, so your talking about 2000 dollars vs 300 dollars.
2)I think drag radials are more street friendly, hard to drive with skinnies around turns.
3)dr also hook great many guys have run 1.5x's and have a more stable feel due to the stiffer sidewall.
Both are a big difference from stock.
NA Bolt-ons GrueBlock C5 Z06 - Forced Induction & Nitrous 10 10-14-2006 07:09 PM
any more bolt-ons?? COUTO1981 C5 Z06 - Pit Road 7 06-11-2005 08:18 AM
best N/A bolt-ons? NastyZo6 C5 Z06 - Pit Road 14 03-12-2005 09:36 AM
03 Z06 vs 00 TransAm Bolt ons + 125 shot Adam B Racing 5 07-19-2003 10:07 AM
what bolt ons are best $ for $ SteveYelloZ06 C5 Z06 - Grandstand 7 07-10-2001 07:38 PM
