Old 06-04-2002, 10:57 AM   #1 (permalink)
Asphalt Build-up on F1's
Anyone else experience this?
After a weekend autocross event, I noticed on the inside tread of my right front tire about a 2ft section of the tread was packed with asphalt. There was so much asphalt it actually extended about 1.5 inches beyond the edge of the tread.
I've pulled off as much as I can, now I'm working on removing it from the treads. I need a lift for my garage!!!
CrazedZ06 is offline   Reply With Quote
Old 06-04-2002, 11:10 AM   #2 (permalink)
DJWorm's Avatar
To clean tires use
Pro Blends Race Tire Cleaner, Part# 7050.
www.pro-blend.com
Some of the stuff you pick up at AutoX events is not asphalt but melted rubber from other people's tires.
AMSOIL Online Store
Old 06-04-2002, 11:59 AM   #3 (permalink)
Yep that's melted rubber alright. You can scuff it off by running hard and turning the wheel back and forth. I let a buddy of mine drive one session at Willow Springs and he was off the line and came back in with the tires coated with that crap. It took me 3 intense laps that felt like I was driving on ball bearings for it all to come off. Chuncks of rubber were flying everywhere, even in the window of the car on corners. Drive it hard.
Lonnie is offline   Reply With Quote
Old 06-04-2002, 12:51 PM   #4 (permalink)
DJWorm's Avatar
Orrrrrr.......You can take the wheel off, get a lawn chair and sit on your patio and pick the "scabs" off. I do this sometimes with a paint scraper or screwdriver. Using the Pro Blend Race Tire Cleaner will make it easier as after an application you can just peel the "scabs" right off.
When is the first build date for the C6 azzkiknZO6 C6 Z06 - Grandstand 7 01-15-2004 01:17 PM
427 build up Brandon619 C5 Z06 - Pit Road 20 01-05-2004 06:30 PM
Build time? gsjack C5 Z06 - Grandstand 17 11-26-2003 05:12 PM
Just build it yourself hummpdady The Garage 16 06-02-2003 09:35 AM
Wheel Cleaner Safe For Asphalt/Sealer Driveway? rwd C5 Z06 - Grandstand 2 07-23-2002 08:20 PM
