Old 03-21-2006, 09:07 PM   #1 (permalink)
BFG DR Tire Pressure?
Making my first trip to the dragstrip, IRP, next Tuesday - weather permitting. Using 345 18 BFG DR's. What tire pressure should I start with? I've read some other posts and saw 15psi recommended for Nitto DR's. Same for BFG?
Any thoughts or personal experience appreciated.
2004 ZO6, Silver/Black, Procharger D1SC, Dynatech headers/x-pipe/high flow cats, Corsa mufflers/tips, 8 rib pulley system, differential brace, hardened output shafts, RPS Clutch, Line lock, BPP heat and pressure extractor hood, BPP shifter, Tiger Shark front end, BPP Headlights, 557 rwhp, 459 rwt
jpm71 is offline   Reply With Quote
Old 03-21-2006, 09:25 PM   #2 (permalink)
That sounds low. Start at like 19-20 & adjust from there.
ron
Old 03-21-2006, 10:49 PM   #3 (permalink)
I agree. Anything between 18 - 24 psi is a good start. Try different pressures and good luck.
Alex
ZO6 AL-X is online now   Reply With Quote
Old 03-22-2006, 07:13 AM   #4 (permalink)
Thanks - I'll start with 20. Driver will probably need more adjustments than the tires.
Old 03-22-2006, 12:19 PM   #5 (permalink)
You don't even know......
Practice, seat time & research here are the best mods sometimes.
Ron
Old 04-24-2006, 11:50 AM   #6 (permalink)
I went out with them for the first time last weekend.. 18psi, 1.9 60'.. could see some improvement.. but they hooked well.. i bogged a few times.. wasnt ready for them too hook that well.
dmotoguy is offline   Reply With Quote
Old 04-24-2006, 12:25 PM   #7 (permalink)
I ran my 315 35 17 bfg drag radials as low as 15psi warm.(best 1.50)
My rwhp was between 370-400rwhp at the time. I was launching between 4200 and 5500 depending on track and conditions. Always did big burnouts. I would suspect the 18" inch bfg's would be fine at 15 psi IF you need the traction. Alot depends on the rwhp of your car,burnout, clutch slip, track conditions etc. I would start at 18 psi and work my way down and be sure to record all the data on each and every launch. Check tire pressure after each run and make small changes. Goodluck.
03 Z06 H/C
9.985@138.80
Best 60' 1.41
Old 04-24-2006, 12:26 PM   #8 (permalink)
You need to launch higher and don't dump the clutch to avoid bog.
Tire Choice Opinions: M/T, Nitto, BFG, Hoosier? MPRTKLR C5 Z06 - Pit Road 4 09-17-2006 04:05 PM
315/30 BFG DRs on stock rears, optimal tire pressure? Pakisho C5 Z06 - Pit Road 1 02-16-2006 02:50 PM
Tire Pressure for BFG Drag Radials? RalphP Racing 31 06-26-2005 02:47 PM
BFG DR Tire Pressure? Need some Opinons.... Hye06 Racing 13 03-05-2003 11:07 AM
BFG Gforc KD 265-35-18 1 left tire! TGVettes Member Sales - Parts & Cars 5 12-20-2002 10:53 AM
