Old 09-09-2002, 10:11 AM   #1 (permalink)
Brake Maint. Questions
I searched for the following and I know I've seen it before, but I can't find it.
1) What is the part number for stock 02 Z06 rotors.
2) I recently ordered a set of stock pads from gmpartsdirect. 88052008 for the front and 12530688 for the rear (since 88952502 is not available anymore). During a 3 day OT weekend, the fronts only wore by half, but the rears were completely gone by Sunday afternoon. When I had the car at the track with the original set of rear pads, everything wore pretty evenly. Anyone know what's up with the switch in part number?
3) When changing brake fluid types. Say from DOT 4 to Super Blue or vice-versa, does the ABS module need special attention. If so, what?
Thanks.
jknight is offline   Reply With Quote
Old 09-09-2002, 01:12 PM   #2 (permalink)
1. Stock Rotor Part #?
2. So the pre-02 pads are inferior to the '02 pads! Latest I heard was "production problems" for the '02 pads ?? Could just be profit margin on the one-off pad, so GM decided to not bother carrying them.
3. I've never done anything special with the ABS module... but others have stronger opinions on this topic...
Dreamin is offline   Reply With Quote
Old 09-09-2002, 02:13 PM   #3 (permalink)
Thanks Dreamin.
1) I knew I had seen that before. I suck at picking the right search words.
2) Bummer
3) Other opinions like you should cycle the ABS module while bleeding?
just hit 1,000 miles on my z (do i need too do any maint) brian 2007 z06 C6 Z06 - Grandstand 14 12-01-2006 09:04 PM
Brake Questions retiredSFer C5 Z06 - Pit Road 8 04-04-2006 06:34 AM
To C4C5....Brake questions?? DJWorm C5 Z06 - Pit Road 7 06-22-2002 03:06 PM
Maintenance Intervals/Routine Maint? skremese The Garage 1 09-17-2001 05:41 PM
