Old 09-27-2003, 08:07 AM   #1 (permalink)
Camber Bolts
Do the Camber Bolts with the T-1 set up have a pre-set camber angle on them or are they adjustable? How much neg. camber can you get?
Thanks/Dave
LtMash1A is offline   Reply With Quote
Old 09-27-2003, 10:35 AM   #2 (permalink)
New product! C5 Camber kit
T1 or Coil Overs
Old 09-27-2003, 12:07 PM   #3 (permalink)
Dave,
The T1 camber plates are a plate with a notch in them, so yes, camber/caster is essentially fixed when you put them in.
They are designed to work the rest of the GM Performance Parts T1 suspension system (anti-sway bars, leaf spring, shocks, stiffer front a-arm bushings). They give lots of negative camber with this suspension. Not sure how much they give on the stock suspension, but I'm guessing just over -2.0.
I used them for the first time last week at the runoffs on the outside suspension only with good results.
More Rear Camber? AlanC Racing 12 06-03-2005 08:30 AM
2004 Camber Changes??? TRZ06 C5 Z06 - Grandstand 0 01-25-2004 12:48 PM
Camber Change LtMash1A Racing 1 06-07-2003 06:07 AM
Negative Camber? urpow C5 Z06 - Pit Road 7 12-04-2002 08:58 PM
Camber Settings TRZ06 C5 Z06 - Grandstand 2 01-18-2002 10:03 PM
