Old 05-09-2005, 08:21 PM   #1 (permalink)
Bob
CG-Lock?
Has anyone used the CG-Lock with their stock seat belt. It is designed to hold your hips into the seat. It is advertised in Grassroots Motorsports as SCCA National SOLO compliant. What do you think?
Old 05-09-2005, 10:21 PM   #2 (permalink)
I saw this item demonstrated at SEMA and it looked like a great, cheap simple solution. If you can't go to a full harness, I expect this would be a nice improvement on stock.
I haven't actually used one myself however.
Nocturne is offline   Reply With Quote
Old 05-09-2005, 10:23 PM   #3 (permalink)
You may already know this, but the stock belts already have this feature. While seated, pull the lap belt retractor all the way out, then feed it back in until it is really snug. It should lock there, holding the lap belt tight. The shoulder harness doesn't do this - too bad - but this should help.
Ag-Z06 is offline   Reply With Quote
Old 05-10-2005, 06:58 AM   #4 (permalink)
to get it nice and tight, slide your seat back prior to doing this, then slide it back to your driving position to get the belt snug.
freefall is offline   Reply With Quote
Lock em up !! Black_Magic Banner Pictures 1 12-30-2003 11:25 PM
'03 colum lock does not lock GotZ06? C5 Z06 - Pit Road 2 11-24-2003 06:09 PM
Remote Key Doesn't Lock the Lock? lundgren C5 Z06 - Pit Road 1 07-27-2003 11:01 AM
column lock help??? alzo6 C5 Z06 - Pit Road 1 07-13-2003 01:17 PM
Column Lock Bypass Kit...prevent 'lock-up' on your Z06 RG Vendor Sales - C5 20 02-02-2001 08:05 AM
