Originally Posted by OKsweetrides
How do you like running 4x315's ? How's the dynamics of the car feel with that combo?
My experience may be a little misleading. With with the 315s shoehorned onto the 17x10 wheels up front, the tire notably bulges and I'm not getting the full contact patch while cornering. In cornering, I can tell the difference between the 275s and the 315s but the difference is very subtle. Where I think the 315s help is under braking where I believe the tire squats and gets a bigger bite. Plus there is more mass so they may absorb and dissipate heat better.
On the downside, they are wider and heavier and I've heard that the 275s up front are faster on high speed speed tracks like Road America.
If I weren't constrained by class rules, I'd probably run an 18" wheel up front with a 295 tire, and a 17" with a 315 in the back.
