Jose,
I am not a drag racer although I have made a few passes.
I think you will need a little toe-in as the car will tend to toe out some when moving.
0 camber sounds correct.
What you need to figure out is what alignment specs will allow the car/tires to roll the easist under 1/4 mile of acceleration.
No easy task.
Others on this forum are much more knowledgable on this subject. Hopefully they will join in.
Dave
533 rwhp 438 rwtq
