Old 01-18-2005, 10:34 PM   #1 (permalink)
Send a message via AIM to LS6NickM
Drag Radial Tire Pressure
Hey guys, im taking my car to moroso tommorow night for the test and tune night. The temps should be about 60-65. Im just wondering what ideal tire pressure for my Nitto 555r drag radials would be. They are 305/35/18s on stock size z06 wheels. Thanks in advance for any advice, and ill keep everyone updated on what I run. PS this is the first time with this car at the track
2001 Quicksiler/Black Z06, Borla Headers, 2 Tip Stingers
MSD Wires, Ported TB, Carbon Fiber Air Bridge
K&N Intake, Fan/Cooling Kit
LS6NickM is offline   Reply With Quote
Old 01-18-2005, 11:06 PM   #2 (permalink)
I originally started racing these at 18 PSI, but now I normally drop to 16.5 PSI . I ran Sunday with 14.5 to 15.5 PSI and pulled off my best 60' ever (1.618) with the Nitto 305/35/18. But my best trap was running at the 16.5 PSI. I'm checking pressure when the tires are lukewarm.
Vararam, Nitto DRs, SpecIII, Air Bridge..... Best 1/4...11.405 @ 123.61.............& B&M Shifter
Qksvr is offline   Reply With Quote
Old 01-18-2005, 11:41 PM   #3 (permalink)
Last time on the track I ran 14 psi, then had it on 13 psi and felt better traction. good luck
MTI stage 2 heads, X1 cam, LG headers, 90mm LSX intake, B&B bullets exhaust system, vararam, air bridge, hurst shifter, Exedy twin disk clutch, tuned by MTI
best E.T 11.78@119 (cam only)
405bhp is offline   Reply With Quote
Old 01-19-2005, 06:48 AM   #4 (permalink)
14-16 psi and make sure you do a killer burnout. Nittos need heat!
03 Z06 H/C
9.985@138.80
Best 60' 1.41
Old 01-19-2005, 09:14 AM   #5 (permalink)
Well from what you guys are telling me, I think ill start em around 17 and go down one pound after every pass. Ill let you know how it turns out. Thanks
Old 01-19-2005, 07:54 PM   #6 (permalink)
My best to date was @ 18psi...
Drag Racing Tire Pressure dheller1 C5 Z06 - Pit Road 1 06-20-2007 10:32 AM
Tire Pressure for BFG Drag Radials? RalphP Racing 31 06-26-2005 02:47 PM
drag radial HELP PLEASE zohhhsix C5 Z06 - Pit Road 11 03-05-2004 08:55 PM
Drag radial question MYZO6 Racing 5 02-20-2004 09:43 PM
Drag radial question MYZO6 C5 Z06 - Grandstand 2 02-18-2004 01:19 PM
