So......
You have made 20 passes on a stock 01 clutch with almost 500rwhp and ET streets and it hasn't slipped. That's very encouraging..
How do you heat the tires up? On the ZR-1, I get the tires wet by turning them over a revolution or two in first gear, roll out of the water box, grab second, rev it up to 4 or 5 grand, let out the clutch and ride the brake while they heat up. I've been concerned that the same procedure would get the 01 clutch too hot and it would slip on launch? It seems that may not be the case at all! Any additional info would be great!
Brian A.
90 ZR-1
12.09@118
01 Z06
12.27@115
bone stock
