Old 09-01-2005, 10:25 PM   #1 (permalink)
Alabama's Avatar
First time at the strip.....what a car
I decided to take my car up to the strip with some friends in their hopped up little ricers (actually very nice cars). I have a bone stock 01 Z06 on GY SC's. I got there late and only got one run to dial in my time. On the first run I spun up a bit on launch but ran a 12.79. I thought I could launch a bit better so called my dial in 12.5. First race in the brackets...12.48 @ 115.22!! I lost due to comming in under, but was very happy. Keep in mind I'm bone stock, on stock Goodyears and running them at my normal 33psi, and it was 102 degrees out. I ran one more run later at a 12.66, but in that run the car seemed to pull timing pretty bad nearing reline. Turns out that my accordian style stock intake snorkle was caving in sufficating the motor of air. So I called it good for the night. Being my first time at the drag strip I had a great time and can't wait to get better. I ended up with reaction times of .165, .180, and a -.111 redlight. My 60' were 2.176, 2.040, and 2.036. This car is amazing stock, so easy to run fast.
Has anyone else had this problem with the intake tube? It did it on the way home too when I stepped on it. I would take it off, push it back into shape and when I opened the hood again it was crushed (sucked in). Where is the best place to get a smooth tube replacement?
Why be another moth...be the flame
http://www.z06vette.com/forums/f68/u...natures-84181/
Alabama is offline   Reply With Quote
Old 09-01-2005, 10:30 PM   #2 (permalink)
Speedratchet's Avatar
Sounds like you had a good time!
Visit me at: Speedratchet
Old 09-01-2005, 10:36 PM   #3 (permalink)
Glad to hear you like your Z's performance.
Old 09-02-2005, 12:59 PM   #4 (permalink)
Good job for your frist time out with the Z
Fleetone is offline   Reply With Quote
Old 09-07-2005, 04:48 PM   #5 (permalink)
YumaZ06's Avatar
Never had that happen to me or heard of it happening to any one else. Most of the vendors who support the forum sell "smooth couplers". Look to pay around $39.95 to $49.95 depending on the vendor. Search the web for Corvette parts and you will find a host of vendors that sell this item.
2004 MS/BLK
NCM#31853
Old 09-24-2005, 07:55 AM   #6 (permalink)
Alabama's Avatar
I picked one of the smooth couplers up for about $40. Seems like this will do the trick. That stock snorkel is a POS.
thanks,
Old 09-24-2005, 07:59 AM   #7 (permalink)
115 MPH that's very strong
first time at the drag strip rock Racing 13 04-05-2006 02:30 AM
First time ever at strip kechen22 Racing 6 06-27-2005 05:26 AM
First time at the strip! ChaseN Racing 10 05-10-2005 06:57 PM
First time out to the strip OthreeZ C5 Z06 - Pit Road 8 01-08-2003 10:18 PM
First time to the strip WA 2 FST Racing 29 02-14-2002 08:45 AM
