if you were running drag radials and if you lowered the tire pressure and if you did a good burn-out and if you launched at 4000 rpm or higher then you should have gotten a better 60ft time ... say in the 1.7 range .... then if you took the motor to within 200 rpm of rev limiter before shifting and then if you speed or power shifted without missing a gear then you probably should have run mid-low12s at 116mph...as you can see take lots of IFs all working together to get off a run that represents what the car can do vs what the driver does....consistency is very challenging as is "doing the right things right" ... first just focus on having some fun the other stuff falls into place with practice practice practice.
