Old 10-14-2003, 02:51 PM   #1 (permalink)
g-force drag radials
Hey fellas,
I am wondering how much abuse the stock clutch and rearend will handle with g-force drag radials in an 02 coupe. All responses appreciated. What rpm would you guys launch the car at? Do you think these tires will cause the clutch or rearend to grenade?
thanks
Dave Pontzious is offline   Reply With Quote
Old 10-14-2003, 07:18 PM   #2 (permalink)
zedosix's Avatar
I have these on my mustang. They grab real good. I have the upgraded 8.8 rear axles and never had any problems. I'm sure the vettes rear won't have any problems handling the extra bite.
2007 Z06 BLK
zedosix is offline   Reply With Quote
Old 10-14-2003, 07:37 PM   #3 (permalink)
Send a message via AIM to robiferretti
i dont know of anyone who has broken any drivetrain parts with drag radials...i know ET streets can do some damage
robiferretti is offline   Reply With Quote
Old 10-14-2003, 08:52 PM   #4 (permalink)
Super Moderator
FRC Tom's Avatar
I know of a 461 rwhp Z06 that broke the pinion gear last Thurs., towed it out to Antivenom's replaced the pinion gear and on Sat. the whole case blew apart.
Moving to Racing.
It is what it is
Old 10-19-2003, 11:44 PM   #5 (permalink)
the only thing you will have problems with is the clutch, but it will last a while, a lot longer than if u had et streets
2002 red/blk halltech sidewinder cf, intake, borla stinger catback, bypasstube, 315/30/18 G force bfg drag radials, LS6 edit, flp long tube headers no cats ported and polished t.b. hurst,dyno at 408 rear wheel. horse. 12.14 at 115.45 first time down track LAST TIME DOWN TRACK 11.65 AT 119.23
kent menges is offline   Reply With Quote
Old 10-20-2003, 12:20 PM   #6 (permalink)
Send a message via Yahoo to Coyote-Z
I am stock with exception to the "Zip tie Mod" and BFG g-force 315/30/18's on the back. Last night, I believe I snapped the output shaft on my final run shifting into 2nd gear.
Coyote-Z is offline   Reply With Quote
Old 10-21-2003, 09:22 PM   #7 (permalink)
Yep. Just got the "news". It sheared right at the diff.
Note to self: No more 5000 rpm launches with DR's@18psi and stock motor.
Nitto 555r or G force drag radials.... 10SecDSM C5 Z06 - Pit Road 5 12-17-2004 10:51 AM
BFG G-force Drag Radials...initial impressions WA 2 FST C5 Z06 - Pit Road 8 01-27-2004 08:41 PM
Anyone running G-force drag radials full-time? WA 2 FST C5 Z06 - Pit Road 25 11-11-2003 05:18 PM
FS: BFG G-Force Drag Radials, stock size amerkin Member Sales - Parts & Cars 4 09-10-2003 06:30 PM
BF Goodrich g-force t/a drag radials Il_Corvette_Giallo Member Sales - Parts & Cars 6 08-20-2003 07:44 PM
