Old 03-20-2005, 08:49 AM   #1 (permalink)
Bob
Getting tires to the track
Is it possible to transport an extra set of wheels and tires to the track in a Zo6 (assume stock size wheels and tires)?
Old 03-20-2005, 08:52 AM   #2 (permalink)
One in the right front seat and one in the trunk lid open. Not good.
Old 03-20-2005, 08:54 AM   #3 (permalink)
Mark Olson's Avatar
I could do it in my C5 coup, but not in the Z06. In the C5 coup I still had one tire setting in the passenger seat.
Old 03-20-2005, 12:51 PM   #4 (permalink)
I just did a dry run of this, as I was wondering the same thing. I WAS able to get a set of inflated 26x11.5x17 ET Streets mounted on rims into the trunk "area" from the passenger side. Remove partition if you have one. Move the passenger seat all the way forward. Tilt the seat forward all the way using the little lever on the back of the seat near the top of the headrest. Place the tire into the car standing up but with the lug holes pointing front to back of the car. Once into the car, lay the wheel down towards the trunk & while holding the seat back forward with your back or butt, slide the wheel into the trunk area, then go to the trunk & pull the wheel all the way in & to the driver's side. Repeat for the 2nd tire & you're good to go!
You could remove the seat also & this would make it easier & give you obviously more room as well.
Ron
Old 03-21-2005, 07:51 AM   #5 (permalink)
Redshift's Avatar
I had a trailer hitch on my Z06 and towed a small tire trailer that I built a platform on top of to get the tires there.
Brian A. Marks
Old 03-26-2005, 08:57 AM   #6 (permalink)
For all the trailer queens out there, stock sized CCW's with hoosiers will fit in the car, along with a jack, toolbox, cooler and lawnchair. Put one front tire in the right rear (it goes in from the pass.side) and one rear tire ahead of it in the right rear. I fold up one towel to put over the center console, then put the other front and rear tires in the front seat. I then roll up a towel and wedge it between the tires and the pass.door. There are obvious drawbacks to all this, but it's certainly possible. Just two drag tires of any size should be cake!
jimshepp1 is offline   Reply With Quote
Old 03-26-2005, 04:43 PM   #7 (permalink)
I just today did it for the 1st time. Even fit a light weight jack back there... See my post above on my dry run that confirmed it was possible.
Ron
Old 03-26-2005, 08:41 PM   #8 (permalink)
You could buy a small trailer for the tires....I just happen to have one I am not using
I would but can't
REDGAR is offline   Reply With Quote
New track tires, used track pads and used tires for sale sleeper02Z06 Member Sales - Parts & Cars 1 08-29-2006 12:05 PM
Z06 track stuff for sale - including full set of CCW track wheels and RA1 tires [PICS Redshift Member Sales - Parts & Cars 0 04-25-2005 07:45 AM
Track Tires Z06 UK Racing 18 09-26-2002 03:38 PM
Best track tires? phil385 C5 Z06 - Pit Road 39 08-28-2002 03:41 PM
Track Tires??????? SteveNix C5 Z06 - Pit Road 2 02-06-2002 11:58 PM
