Old 05-12-2006, 08:35 PM   #1 (permalink)
rock's Avatar
Going to the drag strip tomorrow
Second time at the track hopping to do better. 13.8 was my best of 4 runs last time. Going to lower my tire pressure, and launch about 2000 rpm.
rock is offline   Reply With Quote
Old 05-12-2006, 08:53 PM   #2 (permalink)
rock's Avatar
Also what does it mean to slip the clutch, and how do you do it. thanks.
Old 05-12-2006, 10:17 PM   #3 (permalink)
Send a message via MSN to itchynackers
If you don't know what it means, you probably shouldn't be racing, no offense. Is it a manual or automatic?
FOR SALE
2003 Blk/Blk Z06-Polished Magnuson conversion by LPE, DTE 3.73 stage 4 rear, DTE brace, OZ700 clutch, Brembo cross-drilled rotors, blue LED interior, Corsa Ti Competition exhaust, 507 rwhp
itchynackers is offline   Reply With Quote
Old 05-12-2006, 10:58 PM   #4 (permalink)
rock's Avatar
It is a o3z. The last time out I launched from idle.
Old 05-13-2006, 01:13 AM   #5 (permalink)
IVOZ06's Avatar
Send a message via Yahoo to IVOZ06
HI
Sorry, I thought this thread was about something else...
I was going to complain to the Moderators about the men in drag stripping...
JACK
I do not suffer from insanity, I enjoy every minute of it!
CLICK FOR MY PICS
LIFE IS TOO SHORT, HAVE FUN, NO REGRETS
IVOZ06 is offline   Reply With Quote
Old 05-13-2006, 07:46 AM   #6 (permalink)
Hi there. Make sure traction control is off and run in COMP mode. Try and do a burnout if you can and set the tires to around 20 psi in rear. If you get the tires hot and the track has some prep, you should be able to launch around 2500-3000 but MUST slip the clutch. Don't fully stomp the gas until the tires bite. Slipping the clutch is letting it out slower than if you just pulled your foot of it(dump). As you release the clutch then you should be squeezing the gas not mashing the pedal. It takes alot of practice. Some wheelspin is fine, just try and prevent bog and your times will drop quickly. Shoot for sub 2.0 second 60' times. Goodluck and practice.
03 Z06 H/C
9.985@138.80
Best 60' 1.41
Old 05-13-2006, 10:05 AM   #7 (permalink)
MikesZ06's Avatar
Geez, bro. WTF??
The man asked a question and you tell him he shouldn't be racing
9.87 at 141mph
& 2007 Black C6 Z06
Old 05-13-2006, 11:17 AM   #8 (permalink)
rock's Avatar
Thanks Robz that is some good info. I will be going out to the strip latter today.
Old 05-13-2006, 05:42 PM   #9 (permalink)
Slipping the clutch is the same as riding the clutch out a little.
Listen to what Rob said above as well.
Ron
drag strip times cobra9646 C5 Z06 - Grandstand 14 08-08-2006 09:52 PM
first time at the drag strip rock Racing 13 04-05-2006 02:30 AM
Help on How to Launch at Drag Strip ZO6Deuce Racing 5 02-24-2004 05:27 PM
Drag strip Z06 UK Racing 3 03-01-2001 12:16 AM
Drag Strip, or No? Zippy Racing 8 02-20-2001 01:29 AM
