I read lots of posts about people having a soft and spongy pedal. I have the problem on a 2002 ZO6. Just changed to goodrich steel braided lines with AN fittings... Hardly any change in the pedal feel. Have bleed the system using the two man system about 4 times, basically no real change anytime.
I'm beggining to wonder if I should change the master cylinder, the brake booster or something else???
I was using ate super blue fluid, but just changed to motul 600 during the last bleed, napa rotors, pfc z rated pads. The car sees some daily driving and 6-8 trackdays a year.
Basically the pedal is soft, you can push it in a long way before it actually goes to lockup(abs). On bleeds, I can hold it in on modertly hard pressure, as soon as the bleeder is cracked the pedal goes to the floor, the problem is that additional pedal travel is only 1-2 inches,,, basically very little.
So, if I put on a smaller brake booster, would that help the feeling, or maybe my booster is bad and I can get a new one,,, any thoughts? I don't think bleeding is the issue, but maybe a power bleeder and the tech tool method might help?
Has anyone actually ever fixed their soft feeling?
I think this might be a C5 thing. Pedal feel sux, but the brakes still work like they should. I'd be interested to know what others say. If there is an easy fix to improve brake pedal feel I'm all ears.
Yes. Baer's 4-piston Alcon calipers front and rear, 14" rotors, with SS Goodridge lines, and Motul SRF hi-temp fluids... pedal feel is rock solid and the Beast stops on a dime with a nickel and four cents change...
Its the high quality (Alcon, AP, Brembo, PFC) non-floating calipers. With the booster I'm sure the car has a rigid enough pedal mount (with non-assisted race car brakes, a rigid pedal is very important). The SS line a little.
I'll bet those Alcons also have a good Hawke, Ferodo, or PFC pad.
The Wilwoods, Sierras, are ok. Their also US Brake with an interesting design. The open bridges from Outlaw and Wilwood are non-starters on asphalt.
With the SS lines, very low rotor runout, aligned calipers that aren't binding, and good pads, the floating system can work ok. Many oval classes, including the NASCAR late models, require the GM floating brakes (off an Impala or Malibu).
I have the goodrich lines with ATE blue my pedal is fine ,then again I never had a problem to begin with,it just feels even better now(it is firmer than before)
Goodridge SS lines with Motul600 fluids, cross drilled/slotted rotors and Hawk HPS pads. My pedal feels much firmer than stock and i have minimal brake fade.
Dave
2002 Electron Blue Z06 (sold 1/18/06 )
2006 Daytona Sunset Orange Metallic Z51
Vararam Snake Charmer, B&B Bullets....few others on their way.
For the low, low price of......
Really, the killer on those kind of braking systems is the consumables. How much are replacement rotors for those bad boys?
You could have air in the master cylinder. Bleed that first.
Another possibility is tapered pads. If you do DE events you probably have tapered pads. The caliper has to deflect enough to get the pad friction surface flat to the rotor. I think this would be apparent if you had a solid pedal with the engine off (no boost) and a spongy pedal with the engine running.
I think Dmtnt (?) had a bad mastercylinder or booster some time back that gave him a spongy pedal.
I've had the best luck just using new Motul fluid, Goodridge lines, Carbotech brakes and doing a nice slow gravity bleed until all the air is out. Start on the RR, then do the RF, then LR, then LF. Put full pads on there, good rotors and ensure the calipers aren't old and spread out. The stock calipers tend to spread over time. I replace mine twice a year (I do about 10-12 races/DE events per year). It's a fairly cheap insurance policy. You can get new calipers for about $105 each.
Try that and I'll bet your pedal feel will be what you want. If not, then try the expensive fixes.
I meant techII. The system actually holds four bottles of Motul600. Learned this other day. There is a reserve somewhere in the system as well. Did not know that either.
Jrummi, Go see John Best at West Coast Corvette. He has a Tech 2 and will fulsh and bleed them properly. He stock the Motul fluid as well. Cost with an oil change and your oil is under $90.
Pad taper makes a big difference. Sub Driver posted once that he switches the pads after every so many sessions. I tried this and noticed and improvement.
I had Alcons on another car and the fell is outstanding compared to the PBRs we have. I do believe the Alcons inspire more confidence. I beive they feel like they brake quicker as you don't have to push as far on the pedal. Not so sure they really do as you are limited by the tires. I would love to have a set of Alcons as one suggested, but can't bring myself to spend the money on them.
BTW the PFC Z rated pads do not bite as well IMO as some others when cold, they seam to need some temp to get them working. Try the Carbotechs or Hawk HP + for a street / track set-up. Dedicated track I have had good luck with the PFC 01's but the cost is extreme. I think the Carbotechs are the best value at form vendoer PFYC.com. Brian will set you up with the pads you need to the type of driving you do.
Not sure about the confidence factor on the LGM Wilwoods........Maybe someone will chine in. Most report no pad taper but few comment on the feel compared to stock. Are they right there, right now?, which pads F/R do you like with these?
