Old 03-21-2002, 05:37 PM   #1 (permalink)
having wierd problem on the spray
ihave nos system with msd window activated rpm switch and if i start in first with the juice on it works threw every gear but if i start in 2nd 3rd or 4th the nitrous doesnt turn on.... thats wierd i have no clue on whats wrong
tonybrasco is offline   Reply With Quote
Old 03-21-2002, 09:23 PM   #2 (permalink)
Z06 Power Adder Authority
Very strange. Not sure how yours is hooked up, but that seems so weird.
I've heard the window switches are real finicky, though.
I'm going to try one, too (modified by MSD to work with the coil-on-plug ignition), but if it gives me trouble...its gone.
I plan on arming my system, but activating it with a button on the shift knob I made. This way it will only kick in once I've achieved traction. No sense in activating the nitrous and blowing the tires off.
'06 300C SRT8
'06 Trailblazer SS
Old 03-22-2002, 10:27 AM   #3 (permalink)
Cool button I was try to think which way to do something similiar. Thanks for the pic.
Jose Gonzalez
Primo Racing one bad black Corvette
Jose Gonzalez is offline   Reply With Quote
Old 03-22-2002, 06:42 PM   #4 (permalink)
Thanks! I just picked up my kit today and will begin work on it...although it will be a slow process. I want it done _perfectly_ and this is my first go-round with a late-model GM product.
I have a nice switch panel for it, but I need to figure out where to mount a real stealth bottle pressure gauge. Thinking of getting rid of the cig. lighter in the ashtray and putting on there.
Just a bunch of small logistics have to be taken care of it I want it to be as clean and tricked out as possible.
I can walk you through on the button/shift knob if you need some direction there. Honestly, it was very easy and didn't take much time.
Old 03-23-2002, 05:13 PM   #5 (permalink)
Send a message via ICQ to mr. skelly Send a message via Yahoo to mr. skelly
I hope you have a safety switch mounted somewhere.... To me a button on the shifter is real easy to accidently hit.
mr. skelly is offline   Reply With Quote
Old 03-23-2002, 06:41 PM   #6 (permalink)
I appreciate the concern. I really do. I have built in plenty of safeties. I ran a setup like this on a '96 Cobra I had for 2+ years without a hiccup.
There's an arm switch that has to be ON for the button to be live at all. There's an RPM window switch that has to be ON for the button to be live. There's a full throttle switch which has to be ON for the button to be live.
Plenty of safety.
I did it this way so I have full control over when the nitrous actually kicks in. Using only a WOT means you can't go full throttle in 1st gear without the nitrous coming on and subsequently lighting up the tires...unless you want to be fumbling for the arm switch during the heat of battle. Also, what happens if the road is cool and the car isn't going to hook up on the nitrous in 2nd? Well, I don't want it coming on then either.
In fact, there's a good possibility that I won't be able to use the nitrous effectively til 3rd/4th gear. Thus the reason for the button. All of the other 3 things have to be in place, and THEN the button has to be depressed for the nitrous to activate.
wierd question pauln64 The Garage 1 03-31-2006 06:27 AM
Advice on wierd Pinging Problem? RalphP C5 Z06 - Tuning & Electronics 5 11-07-2005 10:28 PM
Help with new (wierd) noises =( Cobra4B C5 Z06 - Pit Road 5 10-16-2004 08:48 AM
Wierd clutch problem, is it normal for the design, or a problem? Cobra4B C5 Z06 - Pit Road 4 12-23-2003 12:30 PM
Got tints, BUT something wierd with DIC CraZee ZO6 C5 Z06 - Grandstand 9 11-30-2003 08:47 PM
