Brian,
-1.8 front, -1.4 rear will be fine. You will get better performance with more negative camber up front, but it will still be impressive with -1.8.
I'm not sure you can get too much more than that with the stock camber plates, but as DJ said, more is better.
The best way to evaluate your camber setting is to take tire temps immediately after a hot lap. Even temps across the inner third, middle third, and outer third of the tire is ideal. With not enough negative camber, your outer third is likely going to be hotter than your inner third on the outside tires.
Temps of 180-200ish are good.
Have fun!
