Old 09-04-2002, 08:13 PM   #1 (permalink)
racingfast's Avatar
Send a message via Yahoo to racingfast
Hoosier air pressure?
ANYONE running AS303's???? what pressure do you like???
'01 Speedway white/mod red int. RapidMotorsports 427 package, LS2 Block, 573 RWHP, 529 FT LB, 1 7/8 Kooks with no cats or mufflers, RPM Transmission & Quaife Diff, Pfadt Coil-Overs & the propeller!
racingfast is offline   Reply With Quote
Old 09-04-2002, 08:29 PM   #2 (permalink)
DJWorm's Avatar
For concrete 44 front/ 40 rear.
For asphalt 36 front/ 32 rear.
We found this to be the best and identical times on the skid pad. The lower pressures for the asphalt allow the ties to bite more on the slipperier surface. The tires loke the higher psi on the grippier concrete.
Incidently a psi of 40 front / 36 rear is slower
These are col starting pressures and we keep the tires at those pressures as they heat up. You may have to vary these sliightly concerning tire temps, camber and toe and track conditions along with ambient and track temps. We haveactually sprayed water on them between runs when the asphalt was at 130 degrees.
Old 09-05-2002, 03:56 AM   #3 (permalink)
racingfast's Avatar
Thanks DJ
If anyone would know, it would be YOU! I will post in upcoming events the next autocross in Lancaster this sunday....
Brian
http://www.ernccc.org/flyers/e-063.pdf
air pressure sensors??? burnin red C5 Z06 - Pit Road 3 05-21-2006 11:08 PM
Air pressure question BajaZ06 C5 Z06 - Pit Road 2 03-05-2005 06:31 AM
Air Pressure Mikels6 C5 Z06 - Grandstand 8 07-25-2004 02:10 PM
Air Pressure ultra12 C5 Z06 - Pit Road 11 12-18-2003 07:12 AM
Hoosier Tire Pressure for the track DPassell C5 Z06 - Pit Road 14 02-27-2003 05:54 PM
