Old 11-07-2004, 12:16 PM   #1 (permalink)
horrible times with 422
I went to track yesterday after getting my 422 in. I had 5 disappointing runs. It was very easy to miss a gear, so I had to really slow down my shifts.
In my trans am, i had a ripper and a drill mod, and could WING them into gear, very fast. In my zo6, I have a ripper also, no drill mod (I was told you cant do them on a zo6?), and cannot shift near as fast.
How can I speed up my shifts?
Best run was 2.0 60' 11.8ish @ 124
It supposedly dyno'd 475/466 and that was a not a full throttle run supposedly (?). Even so...475 rwhp in a zo6 should = higher than 124.
How much mph am I leaving on the table? That is slow as hell for what the car is, IMO.
Wango Tango is offline   Reply With Quote
Old 11-07-2004, 12:18 PM   #2 (permalink)
with that much torque i would say 127 is about right depending on conditions.
what gears do you have?
Old 11-07-2004, 01:31 PM   #3 (permalink)
I have the 3.42 with of course the M12.
Are shifts slower on y bods than f bods? I could really nail my t/a.
Old 11-07-2004, 02:15 PM   #4 (permalink)
shifting cant be that much worse on these cars. 3.42 are probably holding you down, you could benefit from a quicker 3rd and 4th. you probably shit into 4th and before getting towards the 5000RPM range the race ends.
Old 11-07-2004, 02:48 PM   #5 (permalink)
Try a Hurst shifter
Wango-No experience with the Ripper but the Hurst shifter in my Z06 is a winner! It has a very short throw with a tight pattern. With a little practice you can make extremely fast upshifts, and it is hard to miss a gear. Some of the other aftermarket shifters may be just as good, but I know the Hurst shifter works well. If the Hurst does not help, you may consider looking for a problem with the clutch. The clutches in these cars are a source of problems especially with a modded motor, and hard use. Do a seach on Z06vette for clutch problems before giving up on the Ripper.
02 Electron Blue-Vortex, Hurst, Predator, Andy's Partition, Lloyds mats
67 Camaro 302 DZ, Nash 5 speed, Nitrous, 11.9 at 117.5mph
DonsZ is offline   Reply With Quote
Old 11-07-2004, 02:52 PM   #6 (permalink)
according HP CALCULATOR you making 507hp at the weight of 3400 pounds, so i say you are almmost at the max mph.
http://www.speedworldmotorplex.com/calc.htm
100 shot tnt , vortex ram air, nitto 555r, flp headers system.
vegasredz06 is offline   Reply With Quote
Old 11-07-2004, 03:40 PM   #7 (permalink)
You should be trapping higher in general but alot of factors come into play regarding mph. Including: weather,shifting,60',wheelspin. So, if your new to your car that's probably right until you get it dialed in. Goodluck.
03 Z06 H/C
9.985@138.80
Best 60' 1.41
Old 11-07-2004, 07:04 PM   #8 (permalink)
I noticed some rattling too, which I thought was my shifter. Upon ataping, it was ~ .770-.780...which obviously is lean. The noise could have been detonation. However, nothing showed up on knock sensor, and the plugs looked good.
Horrible Grinding Noise Winchester C5 Z06 - Pit Road 2 06-11-2005 12:32 PM
Horrible day at the track... TheAngryTiTTy Racing 59 04-25-2005 03:21 PM
What causes the horrible rattle... Stangklrws6 C5 Z06 - Grandstand 17 05-14-2004 10:58 AM
This is horrible...(very sad content) getinofficer C5 Z06 - Grandstand 34 06-26-2003 11:00 AM
