Old 04-17-2003, 10:22 AM   #1 (permalink)
how to launch new BFG 295/35R/18
Just purchased (4/17/03) new set of 295/35/18 BFG drag radials from my local Discount Tire store. Will try out tonight at 1/8 mile strip...but i did make several launches (isolated street) on way home from Discount, 30 lbs air at 2600 rpm pop clutch -- BOG, 3600 rpm pop clutch roll a few feet and hit --spin kept and kept spinning, laying two strips of black until i let off. I'll practice multiple lauching techniques tonight but if anyone can save me experimenting runs i would appreciate it....how do you launch drag radials and is some spin desirable??? ---- Discount guys were LOL when they rolled the tires across their floor and the tire picked-up everything in its path...pretty soft and sticky.
C5 CU is offline   Reply With Quote
Old 04-17-2003, 02:27 PM   #2 (permalink)
First off you have to heat them up a little and I run mine at 18 psi at the track and they really hook
2006 Victory Red Z06
490 rwhp 465 rwtq
GaryZ06 is offline   Reply With Quote
Old 04-17-2003, 02:39 PM   #3 (permalink)
Tonight i plan on dropping down to 22lbs and some pre-burn---then i'll experiment on different launch rpms...hoping to find right combination for consistent-low 1.7s 60 ft.
Old 04-17-2003, 09:27 PM   #4 (permalink)
Z06 Power Adder Authority
Please report back!
Old 06-17-2003, 12:34 PM   #5 (permalink)
Hey bro. Just got some 295/35/18's myself. Here is what I did to get them to hook up at 1.7x 60'.
I run mine at 14-18 PSI depending on track conditions. So drop that air PSI.
Then, when on the strip, pull up to the water box, put the car into 2nd gear, rev engine slowly to around 5k, drop clutch and immediately apply foot brake lightly. This will put your car in a looooooooooong burnout sitting there. You should see a plume of smoke 40' high.
Pull up to the line. Stage. Rev engine to around 4K, then launch at light. YOU ARE GONE!!!!!!!!!!
Internet Consultant
Garry
1st. 1994 FRC (Black)
2nd. 2000 FRC (Black)
3rd 2000 Vert (Bowling Green)
4th. 2003 Z06 (Electron Blue)
5th 2005 FRC (Silver)
z06addikt is offline   Reply With Quote
BFG 295 or 325 JPG2003 C5 Z06 - Pit Road 9 02-15-2005 12:27 PM
WTB G-Force BFG 295/35/18's zoomyz06 Member Sales - Parts & Cars 3 06-27-2003 05:52 PM
F/S 2 Used BFG Kd's 295/35/18 robiferretti Member Sales - Parts & Cars 0 04-15-2003 02:13 PM
How to launch on BFG DRs need4sp471 Racing 1 01-18-2003 04:35 PM
2 BFG R1/A 295-35-18 Tires FS Mikie C Member Sales - Parts & Cars 1 12-26-2001 04:10 PM
