Old 04-01-2005, 05:25 PM   #1 (permalink)
Send a message via AIM to FirstGear
How much HP can a stock Z06 take in the drivetrain with DRAG SLICKS?
Looking ahead to this summer, how much HP/TQ can a stock drivetrain take with DRAG SLICKS on the car? I have read about a number of things that go clunk in the night , from shafts to transmission cases....so, what is everyone's experience?
FirstGear is offline   Reply With Quote
Old 04-01-2005, 08:48 PM   #2 (permalink)
ttt
Old 04-01-2005, 10:12 PM   #3 (permalink)
Kat
I haven't run slicks. But we ran 400 plus passes with ET streets with 375 rwhp without a problem. We didn't start breaking chit until we hit 440 rwhp and installed the Exedy dual clutch.
Now we have have a Getreg 3.73 diff with an RPM brace and Rockland trans with a hardend output trans shaft. Our trans was fine but since it was the second trans output shaft we broke my hubby got me the whole trans for Christmas. We also pulled the Dual Exedy and went the the Spec stage 3 since we felt the Exedy was hitting to hard for our car.
So far about 25 passes on current set-up. So far so good
Your results may vary
Old 04-02-2005, 04:40 AM   #4 (permalink)
my concern is the amount of hook up that slicks will provide and its direct beating to the drive train......
Old 04-02-2005, 08:19 AM   #5 (permalink)
Slicks, alone, are NOT the problem...
Rev-limiter launches, aggressive clutches, and ham-fisted shifting ALL take their toll as well...
PowerPro01 sez "STAY TUNED"................ GarettO's the SigGod!
"NOTHING Matters...until you CARE..." Bob Gibson
If RACING was EASY, they'd call it WINNING ! Anonymous
PowerPro01 is offline   Reply With Quote
Old 04-02-2005, 01:21 PM   #6 (permalink)
True, but I broke BADLY on a 5000rpm Drag Radial launch & I'm pretty much stock except the Vararam & tuning. If you dead hook, bad things are possible..I now have hardened parts & a DTE brace.. I've got close to 20 passes under my belt (knocking wood HARD).
Ron
Old 04-02-2005, 02:05 PM   #7 (permalink)
I have seen big cube cars running nos(800 rwt.) not break anything. JoeFiveO's car being one example. Launching at 5,000-7,500 rpm can get ugly. I prefer 3,200.
Grim Reaper is offline   Reply With Quote
Old 04-02-2005, 03:14 PM   #8 (permalink)
Dead hooking is what causes breaking. Drag radials are Worse than E/T streets, because they don't have much sidewall flex, which can absord some of the impact. I would go with what most guys with higher HP cars are doing....Most add at least a hardend left side (long side) Output shaft, and a DTE strut brace. Many people on the Corvette Forum are running this way and having good luck. I haven't heard of anyone breaking a hardened outputshaft, or grenaded a trans or differential with the DTE Brace. I hope that helps. Good Luck!
ForceFedZ06 is offline   Reply With Quote
Old 04-02-2005, 05:31 PM   #9 (permalink)
Yup, that's what i ended up doing.
Ron
??Launch RPM on 18"555R's with stock drivetrain. N2O4YOU Racing 5 09-01-2005 12:03 PM
Drag wheels & Slicks Brandon619 C5 Z06 - Pit Road 1 04-30-2004 08:54 PM
Drag Times and Dyno Run for stock Z06 toofast Racing 6 02-09-2004 08:27 AM
MT Slicks on Stock Z vipereater Racing 6 08-27-2002 10:33 AM
Has anyone put slicks on the stock rear rims? joecooool C5 Z06 - Pit Road 3 07-16-2002 09:22 PM
