View Poll Results: typical launch RPMs outside the dragstrip?
Fastest I routinely launch is 1500 RPM 13 33.33%
Fastest I routinely launch is 2000 RPM 16 41.03%
Fastest I routinely launch is 3000 RPM 5 12.82%
Fastest I routinely launch is 4000 RPM 2 5.13%
Fastest I routinely launch is 5000 RPM 3 7.69%
Voters: 39. You may not vote on this poll
Old 04-03-2005, 04:53 PM   #1 (permalink)
launch RPMs
Just wondering if I'm the only one on the planet who's never launched his Z over about 2000 RPM.
Mine has seen full throttle runs to >6500 RPM plenty enough, and the rev limiter three or four times, but to me it's always seemed abusive to the car to launch a 400 HP vehicle at high RPMs.
Just wondering if there's anybody else out there, or if i'm some kind of freak . Plus, it's not like many other cars can hang with a Z even if you launch it from idle.
novetteyet is offline   Reply With Quote
Old 04-03-2005, 05:02 PM   #2 (permalink)
I never really launch the car on the street...just ease the clutch out and take off. I do pretty much the same thing at the drag strip. I guess that's why I run crappy times.
Si vis pacem, para bellum.
Old 04-03-2005, 05:20 PM   #3 (permalink)
2MchFun's Avatar
I never run mine at the drag strip so, no I don't launch at high RPM with any regularity. That doesn't preclude the [very] occasional smoky takeoff.
Old 04-03-2005, 05:24 PM   #4 (permalink)
DJWorm's Avatar
In Pro Solo we use a Drag Strip type start with XMas Tree.
The launch RPM's all depend on tires and surface conditions. We have used launch RPM's between 2,000 and 4,500.
I would really like to see Launch Control added as the Ferrari Stradale has. Here you pick the RPM and select "LC" ON and the computer then controls everything else for best possible launch time.
AMSOIL Online Store
Old 04-03-2005, 05:27 PM   #5 (permalink)
That would be cool. I would guess that requires the car to have control of the clutch as well as the throttle/etc, so goes hand in hand with those F1-style paddle shifters?
Old 04-03-2005, 05:48 PM   #6 (permalink)
3500-4000rpms on the strip
JohnS is offline   Reply With Quote
Old 04-03-2005, 05:53 PM   #7 (permalink)
Hmm - meant to post this in Grandstand, not the racing section, since it's mostly meaning to ask about street use. Sorry 'bout that.
Old 04-03-2005, 06:28 PM   #8 (permalink)
oops I guess i didnt fully read the poll question.. off the strip usual driving i just ease out of the light.
Old 04-04-2005, 05:04 AM   #9 (permalink)
If you launch over say 2500(depending on temp and road temp) on street tires on the street you'll likely spin anyway. So, not real abusive almost like doing a small burnout and not gonna get u very far.
03 Z06 H/C
9.985@138.80
Best 60' 1.41
Old 04-04-2005, 05:37 AM   #10 (permalink)
I launched at 5300 before on DRs, so I cant vote because theres no option for that, or do you mean on street tires?
Old 04-04-2005, 02:26 PM   #11 (permalink)
DJWorm's Avatar
I moved it to the Racing section because you weren't getting any response in Grandstand and the racers are mainly the ones responding.
You also shouldn't be "launching" on the street, especially at 5 grand. Tsk Tsk
Old 04-04-2005, 02:35 PM   #12 (permalink)
where does it say "on the street" in this thread?
Old 04-04-2005, 04:22 PM   #13 (permalink)
Right here Couto. /\
Old 04-05-2005, 04:16 AM   #14 (permalink)
I didnt see the later post about on the street , so Im changing my answer, I have never really launched it to race on the street, but if I did it would be nothing over 2500 rpm IF that, the z06 is the most worthless street racer ever, with F1s and 32psi on cold street and tires it is on ice, and It feels like it too, we have traction problems on 2nd gear and in the winter 3rd comes into play too, so 1st is out of the question on the street
Old 04-05-2005, 12:11 PM   #15 (permalink)
The F430 has gone one step further and has a computer controlled electronic differential to aid in acceleration and roadholding at the limit.
Torque is continuously distributed between the wheels via two sets of friction discs (one for each driveshaft) controlled by a hydraulic actuator. The amount of torque actually transmitted to the driven wheels depends on driving conditions (accelerator pedal angle, steering angle, yaw acceleration, individual wheel rotation speed) and brings considerable advantages in terms of performance, direction stability, active safety and handling feedback. Again, F1 racing was a vital testbench that enabled Ferrari’s engineers to develop a highly sophisticated system that perfectly matches the requirements of a road car designed to reach over 315 km/h and generate considerable cornering forces.
The electronic differential actively helps reduce Fiorano lap times by 3 seconds compared to the 360 Modena. For the driver, the E-Diff increases handling balance and grip (which noticeably improves acceleration), improves roadholding on the limit and also guarantees even better steering feel.
Cool stuff.
355Spider is offline   Reply With Quote
Hot Oil PSI at 5k rpms? 6k rpms? MPRTKLR C5 Z06 - Pit Road 0 07-23-2006 09:59 PM
engine pinging at low rpms 95formula C5 Z06 - Pit Road 7 05-19-2005 03:21 PM
New Z06 Misses at high RPMs Ron Anderson C5 Z06 - Pit Road 16 01-13-2005 09:09 PM
Headlights Dimming at Low RPMs Matt Cannavino C5 Z06 - Pit Road 3 01-09-2003 03:10 PM
Sounds at 6800 RPMS...... fcalmes C5 Z06 - Pit Road 13 09-08-2002 02:11 PM
