Old 09-04-2002, 08:55 AM   #1 (permalink)
Zed
Launching... and engine cut out..
I find when I launch at a sticky track I go for about 20 feet then the engine cuts out it seems then it goes like an ape.
Does anyone else have a problem.
Zed
Zed is offline   Reply With Quote
Old 09-04-2002, 08:57 AM   #2 (permalink)
Turn off traction control???????
chrissdoug is offline   Reply With Quote
Old 09-04-2002, 09:47 AM   #3 (permalink)
Zed
Traction Control
Traction control is off... I still ran a 12.6 (with a 2.0 60') with the cutout.
Its odd... its kinda like it bogs, but really badly, but I've already launched and gone about 20 feet. The car pulls very hard through all the other gears, I've had it up at 170mph and it pulled through all the gears without a hickup....
I'm kinda confused by this, 1st gear hard launch on a sticky track cutout... I thought it had something to do with axle hop (I don't get much), but even on runs without axle hop it still does this.
Zed
Old 09-04-2002, 10:58 AM   #4 (permalink)
I have experienced it, I raise the launch rpm next run, even then some times it feels a little bog but doesen't show on the time slip. Ric
Old 09-04-2002, 11:02 AM   #5 (permalink)
Zed
Moster Bog
Ahh... so it is Monster Bog!!! I was launching at 3K... and I wasn't slipping as much as I guess I should have (I get excited, forget some of what I try to convince myself of when running). Maybe I will try from 3200, then 3500 etc until it stops doing it.
Zed
Old 09-04-2002, 11:03 AM   #6 (permalink)
MikesZ06's Avatar
Hey Ric, do you feel the extra power of the Vararam during the launch or after you've built up some speed
9.87 at 141mph
& 2007 Black C6 Z06
Old 09-04-2002, 11:29 AM   #7 (permalink)
Is this the wheel hop algorithm kicking in? I've had it too, but seems to be minimal or gone the cooler the motor is.
ASP_Z is offline   Reply With Quote
Old 09-04-2002, 11:47 AM   #8 (permalink)
Send a message via AIM to brent EB02
what you are experiencing.....is abuse management......
or torque management.......we have both on the z and both can be tuned out......
i picked up 4 10ths just with this issue alone...............
02 ZO6 CARTEK 427 600+RWHP 540 RWTQ 10.16@136 MPH
04 GTO STS CARTEK 579 RWHP 639 RWTQ 10.68@129 MPH
10.2@135 MPH VIDEO TURBO GTO 10.68@129 MPH VIDEO
brent EB02 is offline   Reply With Quote
Old 09-04-2002, 12:20 PM   #9 (permalink)
Zed
Editing..
Really???
I had bad wheel hop coming out of the water box at the track (didn't engage any algorithm, so I didn't think it had one).
Does LS1Edit allow one to turn off both of these evil features???
Zed
Old 09-04-2002, 12:21 PM   #10 (permalink)
YES Ric
Old 09-04-2002, 09:50 PM   #11 (permalink)
zed.............ls1 edit and ls6 edit will get rid of this.....
Old 09-06-2002, 10:57 PM   #12 (permalink)
It truly sounds like bog. But make sure your battery is secure JIC.
Since it's probably bog, you can do three things:
Slip the clutch outta the hole. Not advisable with LS6 clutches.
Increase tire pressure. Experiment with higher pressures.
Or my favorite, increase launch RPM. I've only had a handful of Z06 passes, but it seems to hold 4500 pretty good. I doubt if the clutch will take it forever though.
Engine cut out.... Oztek C5 Z06 - Grandstand 8 10-08-2003 08:15 AM
Launching A - ZO6 R/ZO6-LS6 Racing 3 03-27-2003 07:51 AM
Launching need4sp471 Racing 8 11-14-2002 07:39 PM
Engine Cut-Out Z06FRENZY C5 Z06 - Grandstand 1 08-09-2002 06:13 PM
Launching vipereater Racing 1 05-28-2002 07:53 AM
