If you lower to the "factory max." using the stock bolts the shocks will be fine and marginally shorter shaft Koni's or Bilstein's will give you a slight edge.
If you lower greater than the "factory max." using aftermarket bolts then you will need short shaft and body shocks such as the Penske's or JRZ's to take maximum advantage of the lowering. If you retain the stock shocks in this condition they will bottom out and the marginally shorter Konis will hit the bump stops frequently.
I personally recommend Double Adjustable Penske's:
1. Mono Tube racing Shock
2. Reservoir equiped
3. Compression adjustable
4. Rebound adjustable.
5. Inverted design/mounting to save unsprung weight
6. Light weight
7. Revalvable
8. Totally rebuildable. They will outlast you and the car.
9. Easily Upgraded to tripele Adjustables
10. Easily Upgradable to Coil - Over
11. Can Be upgraded with "Third Spring" and Active Suspension
12. Great Factory Support
13. Excelllent Custom builds and valving from Guy Ankeney and Mallett.
14. With an on-Line downloadable Service manual and factory Support they are completely servicable and rebuildable by the owner/racer.
15. If you eventually sell the car they will add to the value or you can easily remove them and sell them outright or move them to your next car.
JRZ's and Moton's are equal in performance and features however are foreign made.
These shocks make it extremely easy to tune the car especially on a dual use car. For example......I use compression settings 1 & 2 (softest) for AutoX, 3 for street use, 4 for Interstate travel, 5 & 6 for the track.....Like the Ronco ad.....set it and forget it.
We dialed in the rebound settings by 1st setting them at mid range (12-14 sweeps). After a few weeks and a couple of skid pad sessions we determined more "turn in" in the front and went to a 21 setting, then with too much rear bounce we dropped the rear rebound to 9 sweeps. The rebound is now perfect for all the compression settings.
We can also easily soften up all 4 compression settings for a wet track and we can decrease the rear compression for a slippery hot track for better traction.
We have also used different compression settings to wheel jack on a raceway.
www.mallettcars.com
www.penskeshocks.com
