Old 02-20-2006, 09:47 AM   #1 (permalink)
Lowering the T1 Suspension
I've read that the T1 package shouldn't be lowered too much as the shocks don't have any more travel than the stockers and will bottom out. I'm OK with this as I'm looking into some custom short body Bilsteins.
The question I've got is relative to something else I've heard; the T1 front spring doesn't allow much lowering. Is this true? I'm not looking to "slam" the car, I just want it to ride at the same height with the T1 springs as it does right now with the factory FE4 springs at the bottom of their factory adjustment range (with no bushing cutting), roughly 1" lower than stock.
I'm not worried about not fitting into any particular racing class as this is primarily a street car.
Is this possible, or will I find it's impossible to lower the car with the T1 springs in there?
Help is appreciated!
'02 EB/MR Z
80% Track, 20% Driver, 100% Z
Old 02-20-2006, 10:19 AM   #2 (permalink)
DJWorm's Avatar
The T1 spring is a stiffer spring with the same recurve as the OEM; therefore it will have a higher ride height than the OEM spring.
If you are NOT going T1 racing then you might consider using:
-VB&P Extreme spring which can be ordered in many more different rates than a T1 and has a better recurve and is lighter
- Penske DA shocks
- VB&P Poly Graphite bushings
- T1 sway bays with teflon lined end links
AMSOIL Online Store
Old 02-20-2006, 10:55 AM   #3 (permalink)
Bob
- Penske DA shocks
Don:
Could you please PM me about where I can purchase the bushings and the end links.
Old 02-20-2006, 03:32 PM   #4 (permalink)
Olitho's Avatar
I just sent a couple of threads To The Top.
They may answer your questions that are very similar to mine.
This will hopefully save DJ and others some wear and tear on the keyboard. They must get tired of the same questions.
sig does not meet site specs
Olitho is offline   Reply With Quote
Old 02-20-2006, 05:00 PM   #5 (permalink)
I don't think that's true, but...
I know with my T1 spring, it can be lowered in the same manner as the stock spring. It doesn't have rubber bushings below it, but a hard plastic, maybe poly, bushing which is thinner than the three stock rubber bushings. Although my T1 spring has almost 30 races on it so it may be flatter than a new one, I know I can lower my car to the point that the tires hit the fender lip on compression. I can get it down to less than a 1" gap from tire to fender.
DJ posted several other good options that might be better for your use.
Z06 suspension upgrades and lowering advice* ?? Kevin D. Racing 37 03-03-2008 07:19 PM
Suspension noise after lowering DeNguyen C5 Z06 - Grandstand 7 08-31-2004 06:16 PM
nightmare with lowering car with the suspension bushings!!! APU6speed C5 Z06 - Pit Road 9 08-20-2004 01:24 AM
Lowering ... and loss of suspension travel question DKTZ06 Racing 9 02-09-2004 05:49 AM
Lowering By Tightening Suspension Components Nazgul C5 Z06 - Pit Road 3 12-24-2002 12:41 PM
