MSD window switch wiring?
I was wondering how some of you got your MSD 8956 window switch wired. Did you send it back to MSD to have it modified to accept a +5 volt square wave, or is there another trick to get this thing to work. And what do you usually set the low RPM and high RPM at. I put my car on a Tech 2 last night, and the car spun to 6754 RPM's. I was thinking about 3000 and 6000. Any suggestions. Oh by the way, I installed a wet system with an NOS fogger nozzle that I had laying around. And anyone familiar with a Tech 2, the O2 was around 930 mVolts on just motor. What should I try to tune this thing to with the juice? Thanks.
2001 Z06: 160 deg thermostat, lowered 1" inch, Hurst shifter, CarTek 0.567"/0.567" Cam, Heads ported & polished by Champion, LS1 Edit & EFI Live.
1964 Corvette Coupe, Best ET: 7.51 @ 189.87, 632 cid, 10.5" Tire & mufflers, 3520 lbs, 18 deg Big Chief Head, Sheet Metal Tunnel Ram, w/Twin Fogger, 4 Stage Dry Sump. [img]http://www.z06vette.com/gallery/data/500/2822vette2.jpg[img]
