Old 01-21-2004, 08:56 PM   #1 (permalink)
Need some Drag Slick advice
I am trying to get some Drag slicks mounted under my car. I got the 427TT setup with boost controller etc and now am trying to figure out what I can do about getting some REAL slicks not ET Streets or Nittos on the car.
The car has been mini tubbed, so there is some room for clearance. The problem is this, I can't seem to find anyone that makes a slick for a 16" rim that isn't 33" tall. Someone out there has to have a solution for getting real slicks on a Z with some serious horsepower.
Any advice would greatly be appreciated.
thepunish is offline   Reply With Quote
Old 01-27-2004, 08:50 PM   #2 (permalink)
Z06 Power Adder Authority
Check Mickey Thompson (you probably already have). I thought they were making an ET Drag tire for a 16" wheel. Probably something like a 26x10x16. You will probably not find anything wider than 10" in something this short (26 or 28" tall).
If you have never run the ET Streets, then you may want to reconsider them. They are _very_ close to the ET Drag tire in both sidewall construction and tread compound. They have some tiny, narrow grooves cut in them to make them DOT legal, but they are not street worthy at all, IMHO (I've run them on another car). The difference in track times b/w the two tires will be negligible for most drivers...we're talking .1-.2 difference.
Good luck!
'06 300C SRT8
'06 Trailblazer SS
Old 01-27-2004, 09:18 PM   #3 (permalink)
MikesZ06's Avatar
Your right, Wes.
Hell after a few burnoffs and races, the groove is pretty much gone and you can't tell M/T ET Streets from M/T ET Drags anyway. The rubber compound is almost identical.
Punish, the other thing you might want to consider with your setup is just how much traction you really want with that bad boy. Unless your like Brent and have an unlimited supply of new halfshafts for free from a local tuner, launching the kind of power you have at high rpm's with great traction is gonna get real expensive, even with hardened shafts.
With your type of tq and hp, you just can't expect the type of consistant hard launches you'd like unless you go to an auto tranny or solid rear end or you're prepared to go through a number of halfshafts and possibly main shafts and clutch plates.
Something to think about.............
9.87 at 141mph
& 2007 Black C6 Z06
Old 01-29-2004, 01:35 PM   #4 (permalink)
Absolutely,
Basically I told John at 21st that if it snaps 2 things in the drivetrain within 60 days, I want to switch it over to Automatic/solid rear end. I am spending all the money on the right parts, so we will see what happens. I decided to go with Hoosier, who makes a slick in a 16 inch size. Cross your fingers, we will see what happens.
Originally posted by MikesZ06
Your right, Wes.
Old 01-31-2004, 04:13 PM   #5 (permalink)
MikesZ06's Avatar
Originally posted by thepunish
Absolutely,
Bro, keep us informed on how those Hoosiers work out for ya. We're all looking for a better mousetrap when it comes to traction and I'm curious if the Hoosiers will be a good option for us.
Old 02-01-2004, 09:29 AM   #6 (permalink)
Mike are you bringing your car to the Clash of the Titan Tuner Shootout in Jackson, SC on Feb 22nd?
A few of those guys will be running Hoosiers
REDGAR is offline   Reply With Quote
Old 02-01-2004, 10:46 AM   #7 (permalink)
MikesZ06's Avatar
I really wish I could. I think that would be a blast. Unfortunately, I will be in Aruba from the 21st - 28th so all I can do is read about it.
Somebody take some pics and vid's will ya!!!
MCRacing is trying to get my Z ready for some type of a 'pump gas only' national competion in Nashville in May, so maybe I'll get a chance to see and compete against the same guys from the tuner shootout.
Old 02-01-2004, 12:38 PM   #8 (permalink)
That is probably the Hot Rod Pump Gas Drags. I did not see your name on the list of 50 at hotrod.com message boards.
I only saw three Vettes on the list.
Old 02-01-2004, 06:23 PM   #9 (permalink)
MikesZ06's Avatar
Don't know much about it Redgar. They simply asked me if we get everything done in time if I would take her out there and race.
Is it limited to only 50 cars?
Old 02-02-2004, 07:39 AM   #10 (permalink)
Yes they picked only 50 cars
For a 6 page artile with all the details, visit
http://www.hotrod.com/upcomingevents/113_0401_pump/
Old 02-02-2004, 10:54 AM   #11 (permalink)
MikesZ06's Avatar
I'll have to ask the MCRacing guys about it. Sounds like I'm screwed on this
Need some advice for the drag strip Amar1995 Racing 6 04-29-2006 12:08 PM
BFG Drag Radial Advice Needed... Z06 Tom C5 Z06 - Pit Road 31 10-21-2003 10:35 AM
Going to the drag strip for the first time - Any advice?? ADE 1000 Racing 7 10-24-2002 06:29 AM
Advice on drag racing the Z06 SilverStateZ06 Racing 14 09-12-2002 02:28 PM
Advice on 1/4 mile drag Larry Steiner Racing 6 08-13-2002 11:58 PM
