Old 08-22-2002, 09:10 AM   #1 (permalink)
New 1/8 Mile Time, and /4 Mile question
sorry
chrissdoug is offline   Reply With Quote
Old 08-22-2002, 10:04 AM   #2 (permalink)
Re: New 1/8 Mile Time, and /4 Mile question
Your buddy's nuts! In similar weather, those 60' and 1/8 times are probably good for 12.0-12.1 @ 115 in the 1/4.
'02 Z06, TR/BK, GHL Magnum Plus, modified airbox, Green Filter,
Optima RedTop, shorty antenna, 6 turns lower
johnboy00 is offline   Reply With Quote
Old 08-22-2002, 10:05 AM   #3 (permalink)
J-Rod's Avatar
Multiply your 1/8 mile time by 1.57 that give you a pretty close idea of what your 1/4 will be. In your case.
12.32921
J-Rod is offline   Reply With Quote
Old 08-22-2002, 01:05 PM   #4 (permalink)
You're low 12 probably.
I ran about that time Sunday, but into a headwind (110mph), and ran 12.27.
Killer 60'!!! What tires?
Blue Meanie 02' Z06 440rwhp AFR 205-224/228, Kook's 1 7/8", SDPC 3.73 Getrag, 11.40@119 w/1.59
SCCA Solo2 ESP #58, Team No $'s. AutoCross Pic
Pat McSwain, co-driver Kathy McSwain
Old 08-22-2002, 01:07 PM   #5 (permalink)
Found the slip:
Fontana, 1100ft, 80deg,headwind=10mph
60'-1.766
1/8-7.879@89.45
1/4-12.272@110.04
Old 08-22-2002, 03:54 PM   #6 (permalink)
315 BFG Drag Radials.
Old 08-22-2002, 06:48 PM   #7 (permalink)
Ernie King's Avatar
Chris
1.80 60'
5.103 330
7.85 1/8
89.89 mph
10.205 1000'
12.20 1/4
112.36
83 degrees
d/a 29.23
So you see your right on the numbers for 12.20 and 12.10's
you get the temp down some and you will see.. Hint... Try and get your oil temp down to 150 or 160, then make your run see what happens.
Ernie
2000 FRC Nassau Blue
10 Second Club
Old 08-23-2002, 09:21 AM   #8 (permalink)
I ran a very similar run in the same weather,
60ft-1.746
1/8 et-7.806
1/8 mph-90.91
1/4 et-12.064
1/4 mph-115.35
I think ur buddy with the 12.5 is out to lunch, one thing i should point out is that 12.0 pass was made after I removed the 30lb inj, and aftermarket intake setup and maft and reinstalled my stock airbox. Before that I was running 12.20's@114, this was all run the same day at the track. After my computer relearned from driving a full week my car picked up another 2 mph in the same heat.
02 Z06 CDN PERF 347 F1C, RPM 4L65E conversion
BEST ET 9.6
BEST MPH 146
vortech is offline   Reply With Quote
Old 08-23-2002, 01:27 PM   #9 (permalink)
Cool, I guess that $50.00 should be mine. He bet me 50 that I could not get 12.5, but thinks I will run 12.7 or more. He said I am not a professional driver...
Old 08-23-2002, 03:01 PM   #10 (permalink)
You've only got one more shift to get you through the last set of lights (1/4), so if you repeat the above 60' time, and hit all your shifts, the money's yours. You'll get your best MPH if you stretch 3rd as close to the rev limit as you can. Be sure and report back here with the result!
Old 08-24-2002, 01:47 PM   #11 (permalink)
What if's have more than a few variables;
60'...1.98
330..5.319
1/8..7.989
mph.94.19
1000.10.297
1/4...12.240
mph..117.01
60'..1.921
330..5.266
1/8..7.938
mph.93.99
1000.10.243
1/4..12.186
mph..116.59
No question your runing better that your friend thinks. Ric
Old 08-26-2002, 07:28 AM   #12 (permalink)
R/T .612
60' 1.860
330' 5.172
1/8 7.910
MPH 90.33
1000 10.267
1/4 12.255
MPH 113.63
R/T .613
60' 1.785
330' 5.166
330' 7.931
MPH 89.66
1000 10.295
1/4 12.292
MPH 112.75
92-95 Degrees
Any guess on that slow MPH???
what should be my 1/4 mile time? zohhhsix C5 Z06 - Forced Induction & Nitrous 9 05-03-2004 04:31 PM
Best 1/4 mile time?? cz06 Racing 2 10-10-2003 12:57 PM
1/4 mile time question BlackWidow Racing 7 05-10-2003 04:44 AM
First Time Ever 1/4 Mile Speedracer Racing 9 06-26-2002 04:20 PM
New 1/4 Mile Time dfunde01 Racing 1 03-19-2002 11:36 AM
