Old 06-11-2002, 02:52 PM   #1 (permalink)
Send a message via AIM to Z OOH 6
New Guy Question about Corvettes...
I read in the manual that we have a feature for trac control called 'Competitive Driving' or something.
Is this recommended at the 1/4 track or just take off trac. control all together?
When I take my 540 to the track, I just take it off and on "some" runs, I get all wheel spin giving me upwards of 2.9 sec. 60' times.
Z OOH 6 is offline   Reply With Quote
Old 06-11-2002, 05:33 PM   #2 (permalink)
Registered User
Send a message via AIM to SpeedDemon
From what I understand (everyone I know does this) is to put it in Competitive Driving mode, this will eliminate the tac control from coming on when you launch and in between shifts. But at the same time if you managed to swing the rear out, you'll still beable to gain control of the car with the active handling.
SpeedDemon is offline   Reply With Quote
Old 06-11-2002, 05:37 PM   #3 (permalink)
THAT'S PRETTY MUCH CORRECT, SD. ALTHOUGH. MOST PROBLABLY JUST TURN IT ALL OFF.
02ZO6 is offline   Reply With Quote
Old 06-11-2002, 06:10 PM   #4 (permalink)
Welcome to the forum TopDogg
Darwin
DBarbosa is offline   Reply With Quote
Old 06-11-2002, 07:39 PM   #5 (permalink)
DJWorm's Avatar
The above advice is correct.
1. The car will always default to AH ON/ TC ON when you start it
2. For drags, AutoX and Road Racing you will want to hold down the console button for +5sec. (seems like and hour) to go to Comp. Mode. Comp. Mode turns OFF the TC but leaves the AH ON. I would advise you to run it this way until you get used to the car and its characteristics.
3. When you are comfortable with the car then you can turn both AH and TC OFF.
4. ALWAYS and I repeat ALWAYS run with AH ON in the wet and rain, on the street and on the track.
Old 06-11-2002, 07:49 PM   #6 (permalink)
Send a message via Yahoo to Rick1
Darwin,
Welcome to the Forum. Lots of good info here.
Rick1 is offline   Reply With Quote
Old 06-11-2002, 08:03 PM   #7 (permalink)
NYCHASM's Avatar
Good advice (as usual) DJWorm. Please expand on 3. above. Tell me any DISADVANTAGE of running with AH on.
Thanks,
Charlie
Old 06-11-2002, 08:34 PM   #8 (permalink)
DJWorm's Avatar
For drags there may not be any disadvantage. However there is for AutoX and Road Racing. It sometimes prevents you from throwing the car in a corner or using power to rotate the car in a corner. You can still do it but the AH will be trying to correct, using the brakes and slowing you down.
If the AH comes on during a drag it will use brakes to correct and it may slow you down, it may also save your ass. It would be a matter of preferrence. Sometimes under hard acceleration you can have a lateral moment due to torque as well, the AH will try to correct that.
Old 06-11-2002, 08:39 PM   #9 (permalink)
NYCHASM's Avatar
Thank you DJ.
I didn't think about the actions of intentionally powering the car through a corner during AutoX and/or road racing. I now see that there might be a disadvantage to AH.
Thanks,
Charlie
Old 06-12-2002, 11:27 AM   #10 (permalink)
MSiska's Avatar
02Z06... SpeedDemon is right. Everybody that drag races with us put it in comp mode. As a matter of fact, at cecil last week, I was headed for a good run (1.96-60'). As I hit 2-3 shift, the rear got real squirrely and was coming close to the wall on the right. AH came on, and saved my ass from hitting the wall. Ranger saw this and asked me about it. Nobody I know will race without it on! That wall is pretty unforgiving.
new guy Z06 question Cloaked C6 Z06 - Grandstand 4 08-18-2006 01:14 PM
Tall Guy Harness Question. methos C5 Z06 - Pit Road 7 02-20-2004 05:59 PM
Another new guy, with a question no less. 3Pedal_Z06 C5 Z06 - Grandstand 8 02-02-2004 10:37 PM
new guy: have a question about the ZO6 Capster78 C5 Z06 - Grandstand 11 10-12-2002 01:02 PM
New guy + noise question Frost The Garage 4 05-08-2002 09:10 AM
