Old 02-22-2006, 03:56 PM   #1 (permalink)
DJWorm's Avatar
New race Tires for C6 Z06 available
Hoosier has released new R Compound tires. Release says these are available for track & AutoX so I am not sure if they are only true R compound or DOT r & A compound or both. IO will research this further.
Available sometime this Spring 2006
New Sizes available:
315/40x19
325/30x19
345/30x19
AMSOIL Online Store
Old 02-22-2006, 04:06 PM   #2 (permalink)
That's good news DJ.
I heard from some guys at the SCCA National at CMP this weekend that Hoosier is going to only one compound on the S05s as they are considering it a dual use tire like the Kumho V710 is, so that may match only one compound for the new tires for the C6 Z06. Consider that second hand info at best...
Old 02-22-2006, 05:57 PM   #3 (permalink)
Send a message via AIM to David Pintaric
There will be an "A" and an "R" compound of the new tire. I hope to have a set for Memphis (in two weeks), but more likely Summit Point at the beginning of April.
David Pintaric is offline   Reply With Quote
Old 02-23-2006, 06:45 AM   #4 (permalink)
MSiska's Avatar
David...I know what R compound tires are. But what are A compound?
Old 02-23-2006, 07:42 AM   #5 (permalink)
No sizes for the front
Old 02-23-2006, 08:02 AM   #6 (permalink)
R = Road racing, a harder compound
A = Autocross, a softer, stickier compound. Lately many T-1 drivers have been using the A compound for racing (20 laps or so).
Frank G.
gonzalezfj is offline   Reply With Quote
Old 02-23-2006, 11:03 AM   #7 (permalink)
DJWorm's Avatar
All tires have a compound rating, similar to UTQR. The lower the rating the "stickier the compound is.
Street tires are = 140 to 220+
High Performance Street Tire = 80 to 140
Race or R compound = 25 to 60
A compound = 35 to 45
Drag compound = 15 to 30
R compound tires have a nominal operating Temp range of 170 to 200 degrees and can tolerate Temps up to 220 before blistering
A compound tires are R compound tires but with a lower nominal operating Temp range. Sometines considereed Qualifying tires. The become sticky at a much lower temp 110 to 140 degrees and blister over 150 degrees.
R compound tires would NOT have enough time to become effective on a 60 second AutoX course where as A compound tires are ready after the first corner or after being preheated.
The lower a tires rating and/or it's temperature range the stickier it is but the lower it's endurance.
DOT A & R tires are essential R compound tires built to DOT requirements, but really not streetable.
Old 02-24-2006, 12:23 PM   #8 (permalink)
There are several 18" Hoosiers in the R/A3S05: 275, 285, 295, 305 and 335. I'm sure these will carry over into the new models.
69LT-1 is offline   Reply With Quote
Old 02-24-2006, 12:45 PM   #9 (permalink)
NOTE: Preheating of tires my any means is illegal in SCCA Solo competition and cause for disqualification.
Old 02-24-2006, 12:46 PM   #10 (permalink)
Also 315, the rear tire size most competitors use in Z06s.
Old 02-24-2006, 01:08 PM   #11 (permalink)
DJWorm's Avatar
Pre heating tires
Correct, it IS illegal to use a Tire Preheater, such as electric or gas heaters, to preheat the tires in SCCA Solo II or Pro Solo competition.
However, it is NOT illegal to preheat the tires using other passive means such as:
1. Running a licensed car on the adjacent street in compliance with all laws prior to an event.
2. Safely operating the car in a circle or figure 8 in the Parking lot or paddock area prior to entering grid
3. Using a slower co-driver to pre heat the tires in a prior event
4. Use thermal tire blankets to passively retain heat
5. Remove the wheels and tires from the car and place them in a heated trailer or car prior to an event.
6. Park the whole car in a heated trailer prior to an event.
Old 02-24-2006, 01:17 PM   #12 (permalink)
DJWorm's Avatar
315's are not available in 18", only 17", so they would NOT be applicable for the C6 Z06 as the 17" would NOT fit over the calipers.
For the C6 Z06, I still recommend:
305/30x18 on 10.5x18 with +0.25" offset FRONT
335/30x18 on 12x18 with +0.25" offset REAR
For the C5 Z06 I recommend:
315/35x17 on 11x17 with +0.25" offset REAR
Old 03-01-2006, 06:07 PM   #13 (permalink)
sweet info
KaZ06 is offline   Reply With Quote
Old 03-01-2006, 07:41 PM   #14 (permalink)
Thanks for sharing.
Will Nitto be offering 555R's/RII's for the C6 Z06 as well?
Alex
Did you use race tires yet? DavidNJ C6 Z06 - Pit Road 12 04-24-2008 07:16 AM
FS: Penske Shocks, Machine Faced Z06 Wheels, Race Tires DKTZ06 Member Sales - Parts & Cars 11 11-01-2005 08:24 PM
Piolot Sport Cup 265/35 18 race tires Z06 C5 SuperZ Member Sales - Parts & Cars 7 12-15-2004 09:19 PM
Got my CCW's and race tires speedpup C5 Z06 - Pit Road 4 03-25-2004 08:03 PM
Toyo race tires vonkathy Racing 9 03-30-2003 09:52 PM
