Old 09-10-2003, 08:09 AM   #1 (permalink)
NHRA Compliance
Which of the NHRA rules does the stock Z06 meet, and what has to be added to comply if you run in the 11's? DS safety loop, roll cage, etc.
2002 Z06 Black/Mod Red
"Politicians never accuse you of 'greed' for wanting other people's money --- only for wanting to keep your own money." (Joseph Sobran)
dfunde01 is offline   Reply With Quote
Old 09-10-2003, 08:11 AM   #2 (permalink)
MikesZ06's Avatar
For elevens, all you should need is a helmet and roll bar for NHRA. Drive shaft loop is not required since our DS tunnel is enclosed.
9.87 at 141mph
& 2007 Black C6 Z06
Old 09-10-2003, 08:17 AM   #3 (permalink)
What Mike said.
Rick
Vortex Rammer/Predator Tune/Painted Fuel Rail Covers (EB)/TB Bypass/160° Stat/Borla 2Tip Stingers/Performance Hood Seal/APC Bulbs/Hurst Shifter/MGW Gripper Knob/Bazooka Tube/Shorty Antenna/Lowered/Zaino
ZEE06RICK is offline   Reply With Quote
Old 09-10-2003, 08:18 AM   #4 (permalink)
How about:
- SFI approved jacket
- SFI approved seat belts
- SFI Flywheel / Clutch / Bellhousing Steel Valve Stems
Old 09-10-2003, 08:21 AM   #5 (permalink)
MikesZ06's Avatar
How about:
Jacket is not required and your oem seat belts, clutch and bellhousing will all pass tech.
Old 09-10-2003, 09:06 AM   #6 (permalink)
Cool. I should be good to go then. They don't care if the bar is bolt in or welded?
Electron Blue/Black '02 Z06 "DRIVE IT LIKE YOU STOLE IT!!"
Vortech V-2 SQ T-Trim Aftercooled Supercharger, AFR 205's, Custom Grind "Blower" Cam, SPEC Clutch, Fidanza Aluminum Flywheel, Hardened Output Shaft, 3:73 Rear Gears And A Bunch Of Other Cool Junk...
Z06 Tom is offline   Reply With Quote
Old 10-03-2003, 01:13 PM   #7 (permalink)
They care, but they might not notice. Get a rule book, if you read it closely you might and probably will get a head ache,if your trying to fit the intent of rules, most local tracks will want you to have a good time; safely. Ric
Have you ever been to a NHRA National? jub jub Quarter Mile 17 10-25-2006 04:02 PM
Picture size compliance. PerforminNorman Site Questions or Suggestions 4 07-28-2005 11:50 AM
NHRA Rule's MuffinMan Racing 6 07-21-2005 10:20 AM
Arizona: anyone going to the NHRA FarhadZO6 The Garage 0 03-04-2004 10:38 PM
NHRA Rules dfunde01 Racing 3 02-15-2002 05:06 PM
