06-17-2005, 06:15 AM
#1 (permalink )
Nitto 555R Drag Radials
Hi All,
What PSI should I be running at the drag strip using the Nitto 555R Drag Radials? I have heard 15 PSI up to 25 PSI.
Any recommendations?
Thanks in advance.
06-17-2005, 07:40 AM
#2 (permalink )
I found that at 21 psi in the stang I had was the best. I dont have those tires on the VET yet. Dr.Bigg
06-17-2005, 09:07 AM
#3 (permalink )
Hey Sunrise! Try 18psi....Any new track results to speak of???
Ron
06-17-2005, 09:30 AM
#4 (permalink )
Ron
Hi Ron,
Thanks...I will try that! No new numbers yet...hopefully some good numbers this evening but the DA tonight would be around +2900 DA which is not favorable.
Sunrise
06-17-2005, 02:46 PM
#5 (permalink )
Originally Posted by sunrise
Hi All,
Thanks in advance.
15-16 psi should be best.
03 Z06 H/C
9.985@138.80
Best 60' 1.41
06-17-2005, 03:45 PM
#6 (permalink )
Experiment with 15-20 psi. Don't forget to post results.
Alex
2003 Z06 - Tint | C6 Z06 Shifter w/Knob | GHL 2-Tip Magnums | Z06 Exhaust Plate | Hood Seal | Zip-Tie Intake | 1-4 Shift Defeat | NGK TR 55s | Nitto 555 RIIs.
My BPP Shifter Broke In Two!!
06-17-2005, 03:59 PM
#7 (permalink )
Alex
AL, would you say the same for the R2's ? The sidewall is so stiff I'm wondering.
'02 QS, Intercooled Magnacharger, ACI Radical Hi rise hood, Nitto R2's, Partition, mats, etc
06-17-2005, 05:07 PM
#8 (permalink )
I don't have my RIIs yet - I get them soon.
Try it and let me know what you think.
Alex
06-18-2005, 06:48 AM
#9 (permalink )
Jed, the r2 work good at 15psi but they are not great launch tires due to the stiff sidewalls. But they hook great once your moving as you know.
Linear Mode
» Site Navigation
» Other Sites
» Sponsor Links
