If you do a search on Drag Radials I think you'll be able to read some informative threads from some other Z06 owners. With a Z06 on stock rims, the main choices are BFG or Nitto 555R. They are both very good drag tires.
But For some guys here even thats not enough, so If you are really serious about the track, you could also look into getting a separate wheel/tire package, then you could run ET streets.
I'd run with some Nittos first and then maybe see if you want to whole hog on the ET's later.
'02 QS, Intercooled Magnacharger, ACI Radical Hi rise hood, Nitto R2's, Partition, mats, etc
