I ran my 2003 Z06 at SGMP on Saturday and had my son doing the tuning. One thing that I'm trying to perfect is the shift points.
Here is my dyno graph.
I can't get my SAE graph to load which put out 430/400 est., so this will do. Anyhow, you can see peak HP is reached at a RPM of 6250, than slowly falls. What shift point would give me the best ET?
Below is a picture of the log we recorded on Saturday. The car ran a 11.7 @ 121 on a 1.88 60'.
Mods are :
AFR 225 heads
224/224 109LSA
LG long tubes
2.5'' stock exhaust, cats removed
stock mufflers
Vararam
FAST90, LS2 TB
Then, the little bit of tuning we have done.... 30* of timing, 13.0 AFR.
Here is the log:
http://i10.tinypic.com/2nrfsjn.jpg
Pics have to be a max of 640X480
I was watching my tach and I was appr. shifting at 6600RPM. Looking at the log, I was shifting at 7100, each gear!
Luckily my son knows I'm a little slow on the shifts and set the limiter at 7200.
Anyways, most of this is just details and my question is where do I need to shift at to get the best ET out of this car?
Thank you,
Bob
