Old 01-24-2003, 05:46 AM   #1 (permalink)
Out Of Control
WENT SAT TO STRIP ,NO MODS ,STOCK TIRES ,RAN 12.70 . ONLY 1000 MI. ON Z .31 PSI ON REAR TIRES ,TEMP WAS 41 DEGREES ,SUNNY . WENT LAST NIGHT , 40 DEGREES ,30 MI HR. WIND , CAME OUT THE SAME EXCEPT I RAN 22 PSI IN REAR .60 FT TIMES WERE THE SAME EXCEPT THE CAR BROKE LOOSE HALF WAY DOWN TRACK ,TRIED 5 RUNS ,EACH TIME IT WAS THE SAME ,I WENT DOWN TO 20 PSI ,NO CHANGE . WAS CONSISTANT AT 13 .0. SOME REGULARS SAID EVERY ONES TIME WAS OFF BECUASE ALL THE KIDS WERE DRAGING WATER UP TO THE LINE . PROBLEM IS THE TEMP. WAS THE SAME ,ONLY DIFFRENCE WAS IT WAS NITE TIME , SHOULD THERE BE 3 TENTHS DIFF.AND LOSS OF CONTROL
JACK FRISSINA
JACK FRISSINA is offline   Reply With Quote
Old 01-24-2003, 08:50 AM   #2 (permalink)
My understanding was that a radial might start cupping in the middle of the tread if the pressure was low unlike the old bias ply tires. As goofy as it sound we always went to a good surface road, spun about 10 feet and looked at the contact patch and adjusted the pressure accordingly. It was easy to see an over inflated tire, it got a little tricky on an under inflated one. Food for thought, Mike
Joslyn is offline   Reply With Quote
FS: Brand new RaceLogic traction control system with launch control jimlab Member Sales - Parts & Cars 14 12-31-2005 03:51 PM
Traction Control rebells6 C5 Z06 - Pit Road 13 08-11-2005 12:48 PM
Traction Control Mike B C5 Z06 - Pit Road 6 11-02-2002 08:50 PM
Climate Control/AC control LAvette C5 Z06 - Pit Road 1 10-12-2001 04:44 PM
