Old 07-11-2004, 10:15 PM   #1 (permalink)
Output shaft, differential strut or both??
Okay I'm at 404 rwhp, probably 430rwhp after I get this new house behind me and get some headers.
I'm looking at drag radials and am thinking for somewhat cheap insurance I should install a hardened output shaft. But then I'm thinking about everything else "while your in there"...So it's hardened output shaft, check the tranny over, reverse gear is a pita sometimes, install steel shift forks and a new clutch and adjustable clutch master cylinder.
CA-Ching!
OR a differential strut from dynotech? Seems like a no brainer if this works like it says it does....I install it myself in 2 hours (according to their website) and I'm done. No hardened output shaft needed?
I have 22k miles on my '02 Z06, what do all of you think???
Old 07-11-2004, 10:46 PM   #2 (permalink)
Paul,
I checked out the differential strut and it looks like a pretty good idea, except it adds 26lbs to the car. The drag radials will make up far more time than 26lbs would lose though.
The writeup made it seem like they couldn't break the drivetrain w/ the strut installed. They make it sound like it's a no brainer. Anybody have any real world experiences?
'03 EB Vararam, B&B Bullets, BK Harness Bar, Goodridge SS Lines, '04 Shocks (Sold)
'06 MS - RBF600 brake fluid upgrade, Recaro Pole Position Seats, Sharkbar, other safety equip.
bpf1970 is offline   Reply With Quote
Old 07-11-2004, 11:13 PM   #3 (permalink)
HP and Torque is nice but only as useful as the overall reliability of the car itself, imo.
That said, it's typically the diff case that cracks or is torn from the trans. When that happens the trans output shaft is bent. This can and has happened due to wheel hop even during relatively normal driving given enough h.p. and toque. For this reason I have the DTE diff/trans strut brace.
Old 07-12-2004, 05:26 AM   #4 (permalink)
J-Rod's Avatar
The brace is no replacement for a hardened shaft...
I would do a shaft first. Especially during a gear swap.
You only end up replacing the shift fork if you bend the stock one. For instance, I still have the stock one in my car after well over 100+ passes.
With all that said, the only two cars I have seen tear the rear diff out of the car on were a 422 on gas, and a heavily moded stroker. Most cars will not tear the case apart. However, the cost of the brace is much less ( and good insurance) in case you get into the situations where you might need one.
We will probably be putting one on Tommy's car this winter. But, after 45-50 passes with a car making 503/455 and leaving @ 6600-6800 (1.4x - 60' typically) everything appears to be fine.
In most street cars, a shaft will be all you need. Several vendors carry them. Prices are all about the same. I like looks of the one from DTE ... We have one from another vendor in the rear currently, and its holding up fine...
J-Rod is offline   Reply With Quote
Old 07-12-2004, 05:24 PM   #5 (permalink)
Just installed the DTE brace last weekend and I can tell you that even on a hoist you are looking at close to four hours.
Exhaust system from headers back needs to be pulled and the reach on some of the upper rod nuts is a PITA.
If for some reason you need to pull your rear end, install it then.
Pat
02 EB/Mod Red, LPE C5R 427 Twin Turbo, Kirban/Delrin, Brembo, HRE, 665 rwhp, 702 rwtq without variable boost.
Mufflerbearing is offline   Reply With Quote
Old 07-22-2004, 01:27 PM   #6 (permalink)
i have both hardened shaft and a brace, although not the DTE brace....and i still don't have the financial confidence to do a 6000rpm clutch dump launch ... I am stuck at 4000rpm launch and 1.7 60ft ... in order for me to have low 1.6 60ft i would have to gut-up to ET-streets and 6000rpm launch and then say hello to 10.9 ....
C5 CU is offline   Reply With Quote
Old 07-22-2004, 02:53 PM   #7 (permalink)
I had a hardened shaft installed sometime back when I needed a clutch. Lots (probably 75) of 6000 launches on et streets with anywhere from 370-400rwhp over the past year.
I recently had RPM in Lewisville install 3.90 gears and their proprietary strut brace since the rear was apart anyways. I saw the piece in person, and even picked it up, and there is no way that thing weighed 26lbs? I'd say a lot less than that. Maybe the DTE piece is heavier? Besides, extra weight at the rear axle isn't as bad as adding weight on the front of the car...
'06 MS Z06
11.31 at 123, 1.80 60ft
showroom stock
BLU-BY-U is offline   Reply With Quote
Old 07-26-2004, 06:44 PM   #8 (permalink)
Where's a link for this strut brace? What does it support or keep from moving under hard acceleration? Keep the driveline straight?
Man 'O War is offline   Reply With Quote
Old 07-27-2004, 06:56 AM   #9 (permalink)
the RPM brace keeps housing from torque-ing and cracking during launch...good product.
Old 07-27-2004, 07:19 AM   #10 (permalink)
MikesZ06's Avatar
I have the hardened half shaft and the hardened main shaft and yesterday we ordered the brace from DynoTech. I got the opportunity to see it already installed on Z06 Tom's Z at the fest and I liked the fit. As J-Rod said, it makes for pretty cheap insurance.
My install costs will be lower of course since the engine is out of the car and it shouldn't take too long to drop the tranny for the install.
9.87 at 141mph
& 2007 Black C6 Z06
Old 07-27-2004, 08:34 AM   #11 (permalink)
Mike,
I can tell I don't get to this board enough, I didn;t know your motor was out - WTF??
BTW I agree on the hardened output shaft - a must have, my dealer installed it for free after I hurt the ring & pinion, I supplied the part.
Les
[sold] 02 QS Z06 383 c.i.
Old 08-05-2004, 06:33 PM   #12 (permalink)
Best money you can spend .......
2005 MDMC Z1100 C6 1105 Flywheel hp 18 psi of boost
D1 Procharger 730RWHP 652RWT very very safe
9.86 @ 142mph
2004 GTO 434 RWHP 11.4 @ 120 hot laped
OpticZ06 is offline   Reply With Quote
Old 08-09-2004, 04:54 PM   #13 (permalink)
Kat
We will be buying one. This is what ours looks like after yesterday
I did get a new best before it blew though
Old 08-09-2004, 06:26 PM   #14 (permalink)
Ernie King's Avatar
Wow, Kat, Sorry to see that happen.. What Rpm did you launch at and what was the 60' time.. I'm a little less in power than you but thats sick..
Ernie
2000 FRC Nassau Blue
10 Second Club
Old 08-09-2004, 06:30 PM   #15 (permalink)
Kat
Ernie
Thanks
Pat thinks appox. 5500 he was driving that pass. No 60ft times.. Maybe 3 inches. It blew on the starting line. We weren't even cutting good 60's yesterday the best was my 1.75
DTE C6 Differential Strut Release>>> Dynotech Eng. Vendor Sales - C5 3 08-24-2005 02:07 PM
DTE Differential Strut Adjustment Procedures Here... Dynotech Eng. C5 Z06 - Pit Road 5 05-30-2005 08:13 AM
*Special* DTE HD 4340 300M Differential Output Shaft Dynotech Eng. Vendor Sales - C5 13 03-30-2005 09:20 AM
Hardened Output and DTE rear Diff Strut FiveOJoe C5 Z06 - Pit Road 14 03-17-2005 10:35 PM
When's a Hardened Output Shaft necessary? Jagrmaister C5 Z06 - Pit Road 30 04-28-2004 02:29 PM
» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
