Penske DA conversion to coilovers - who can do, and $$?
Hey all -
Have been thinking about increasing the stiffness of the car, since I'm still having a tiny bit of rubbing problems with the shorter Penskes, and stock Z06 suspension pieces.
I've got a set of Hotchkiss bars on the way (T1's were just too stiff!), which I suspect will solve the problem.
However, I've been pondering playing with the spring rates a bit too, but the immense cost of the VB&P springs seems prohibitive.
I am curious as to what vendors might be able to take my existing Penske doubles and turn them into a complete coilover set, so I can use the $50/per hypercoils to toy with spring rates. Is this something Ankeny or Mallett can do? What kind of cost is involved, since I already have the shocks? (a significant portion of that cost, no doubt?)
Second, do any of you have hard data on what the Z06 spring rates are? If you were seeking to first duplicate the Z06 rates on a coilover setup, would you have those same numbers on the coils, or half that? i.e, if the Z06 front spring is 600#/in, would you buy 600# coils, or 300# coils? (since there are two of them, versus the one leaf spring?)
Cheers,
-Jake
