Old 07-28-2005, 04:16 AM   #1 (permalink)
PFYC Titanium Pad Plates and Carbotech Pads?
Anyone used this combo? I decided not to install the plates this week because the holes they use to stay in place do not have a corresponding pin on the Carbotech pads. I was afraid they would come loose and be a danger.
Any solutions to this issue?
BQuicksilver is offline   Reply With Quote
Old 07-28-2005, 09:55 PM   #2 (permalink)
Redshift, anyone?
Old 07-29-2005, 07:08 AM   #3 (permalink)
I'll forward this to brian...
freefall is offline   Reply With Quote
Old 07-29-2005, 12:30 PM   #4 (permalink)
Redshift's Avatar
We didn't put the tabs on the ends of them because those would prevent them from working on the C6. Our manufacturer does not believe they will move around or fall out without the tabs in place. Physically speaking I would think it would be difficult for them to move around and slide out, but I am unsure. We could make more with the tabs I guess...
I would be testing these on my own car, but I no longer have it, so that is impossible. If anyone else has ideas on this please ring in.
Brian A. Marks
Old 07-29-2005, 12:38 PM   #5 (permalink)
The Ti plates have holes to help mount them to the tabs on the stock pads. Problem is, the Carbotech pads do not have the same tabs so there is really nothing to hold the Ti plates in place. I didn't feel it was worth risking use of the plates since they could cause a problem.
I'm thinking about adhesives that could withstand heat and still allow removal of the plates.
Old 07-29-2005, 12:40 PM   #6 (permalink)
Redshift's Avatar
Yes, I understand the issue exactly. The tabs I was referring to were the same as on the pad backing plates themselves that hold them in place on the caliper bracket. If we add those tabs, the plates are sure not to move, but the question is will they move without them in place or not.
Old 07-29-2005, 03:20 PM   #7 (permalink)
I just took at look for myself. My Hawk pads had the "nubs", so I didn't even notice the fact that the shields have no tabs on the ends.
This is indeed an issue if you run pads without the "nubs". My suggestion is to use high-temp silicone RTV and glue the plates to the backs of your pads. Silicone itself is a good insulator and should be able to withstand the heat without breaking down.
I used to use ceramic pads instead of Ti, and I always used silicon to hold them in place. It is a slight inconvenience, but they benefits should outweigh the hassle.
Corvette C6R Racer #35 David Farmer
y2khardtop is offline   Reply With Quote
Brake pad alternatives (and best price for Carbotech?) Subw00er C5 Z06 - Pit Road 1 08-14-2006 10:04 AM
Carbotech brake pads where to get them? Backlash Racing 16 04-05-2006 07:22 AM
Carbotech Pad question. kmagvette Racing 10 02-21-2006 04:31 PM
Carbotech pads smithsc C5 Z06 - Pit Road 7 06-05-2005 10:01 AM
Carbotech brake pad install 50th Z06 C5 Z06 - Pit Road 6 03-02-2004 09:38 PM
