Pull after pad & rotor swap
Ok guys, this one has me stumped. I think I'm pretty much done with track days for this season, so I went and ahead and swapped my OE pads and rotors back on. These have only been used together as a set and never with any other pads. I have dedicated track pads & rotors.
Problem is now, when I first apply the brakes, the car tucks it's nose to the left front just a little before the braking evens out and it will track straight under the brakes. I went back through and did a brake bleed on all 4 corners again. No effect. It's almost like one of the calipers is operating on slight delay. None of this behavior was noticable before the pad & rotor swap. I would have certainly noticed it at the track because with quick brake application the front will tuck to the left by 6-12 inches. With slow brake application, it almost just feels like hitting a rut in the road while braking.
Anyone have any ideas of what it could be? Hopefully I'm not first one to have come across this.
Jeremy Lucas
02 Z06 - T1 CCWs, SW header, DL1
