Quickest 60 footer on drag radials?
Was wondering what's the quickest anyone has been on drag radials? Also wondering when people start braking half shafts? I have been 1.61 and 1.65 with the stock 3.42 gear, half shafts and stock clutch. I have seen a 1.45 posted using ET Streets. What's the best one can expect with drag radials?
Thanks,
Jimmy
Who is the best to do a 3.73 gear in Florida?
2001 Z06: 160 deg thermostat, lowered 1" inch, Hurst shifter, CarTek 0.567"/0.567" Cam, Heads ported & polished by Champion, LS1 Edit & EFI Live.
1964 Corvette Coupe, Best ET: 7.51 @ 189.87, 632 cid, 10.5" Tire & mufflers, 3520 lbs, 18 deg Big Chief Head, Sheet Metal Tunnel Ram, w/Twin Fogger, 4 Stage Dry Sump. [img]http://www.z06vette.com/gallery/data/500/2822vette2.jpg[img]
