Old 07-27-2005, 12:31 AM   #1 (permalink)
Send a message via AIM to SCCA_Z06 Send a message via MSN to SCCA_Z06 Send a message via Yahoo to SCCA_Z06
Race Shocks
Not that I have any money, but there is a possibility that I might have a co-driver next year that actually does....
Need as much information on shocks as possible. Dyno curves for Koni SA / DA / Penske SA / DA, Stock 03, Stock 04, etc. Basically anything commercially available. Also, would be very useful to know which settings make the shocks equivalent to stock 04's.Valving information, etc.
Car usage is almost all AutoX - Solo2 & Pro Solos
Can't afford to buy the wrong shocks.
http://www.z06vette.com/forums/showthread.php?t=55935
SCCA_Z06 is offline   Reply With Quote
Old 07-27-2005, 08:28 AM   #2 (permalink)
Get Penske DA's and ask for Pat Salerno's valving...next question.
TedDBere is offline   Reply With Quote
Old 07-27-2005, 09:27 AM   #3 (permalink)
DJWorm's Avatar
Depends on what class you are running. Lowered beyond factory recommendations or not.
Dyno curves on adjustables will vary with valving. No body really is forthcoming with those as they are a trade/racers secret and may be the only advantage for instance, in a stock class.
The double adjustables become a real advantage on a dual purpose car that sees low speed AutoX, some highspeed track work and also is a daily driver.
I recommend Penske DA's set up by Guy Ankeney for Pro Solo and National Tour.
Mallet also has a nice Penske DA set up for the track. His mounting of the reservoirs is superior to any other.
The Penske's already have a threaded outer body so they can be easily converted to coil over and triple adjustable if you move up to SM2
AMSOIL Online Store
Old 07-28-2005, 08:20 PM   #4 (permalink)
Send a message via Yahoo to ghoffman
Ankeny/Penske for the following reasons:
1) Correct valving for specific application
2) Correct (body up) mounting for minimum unsprung weight
3) Correct body length for lowered cars
4) Aluminum body threaded for coil overs (if desired)
5) Adjustable damping for rain or dry dates
6) Completely rebuildable
7) Made in USA (not EU) , all CNC billet construction
ghoffman is offline   Reply With Quote
Old 08-01-2005, 10:49 AM   #5 (permalink)
Sorry, wrong answer.
Ankeny Penske's do not have the correct valving. This is why Salerno isn't using them anymore.
Old 08-01-2005, 11:03 AM   #6 (permalink)
Yup, went to Koni's on the new car, ran the Penske's last year, I guess second in nationals wasn't good enough, lol. No matter what you have, the grass is always greener...it's only money and the Koni's are a lot less expensive. Good luck, looking forward to you getting the new shocks...are you getting the "special" ones or are you going to try the Koni's?
Old 08-01-2005, 01:06 PM   #7 (permalink)
I believe the Konis that Erik Strelnieks is now running cost quite a bit more than the Penske 8100's. Didn't Pat Salerno just change the valving on his Penskes, or did he also buy new shocks? Regardless, it does seem to be a matter of preference, Stacy was able to win last year with Guy's valving. I recently got my Penskes from Guy and was, at first, not sure what I had gotten into...they are valved pretty stiffly and also don't take full advantage of the shortening allowed under current SS rules. After changing my ride height slightly, working on the rebound settings and generally getting used to the shocks, I feel I am going faster...if Erik thinks good shocks are worth .2-.3 on a 45 second course, I feel Guy's shocks have given me at least that improvement. No back to back testing, though, to substantiate what are "seat of the pants" impressions...although, through slaloms and in making mid turn corrections, the benefits are very obvious.
One other thing, Guy is always there to answer questions and try to help, which has been very beneficial.
tigerdrvr is offline   Reply With Quote
Old 08-01-2005, 04:42 PM   #8 (permalink)
Can someone give a phone # or e-mail for Ankeny?
Thanks.
Steve
mountainbiker2 is offline   Reply With Quote
Old 08-01-2005, 05:42 PM   #9 (permalink)
You should be able to find their web site by "googling" Ankeny Racing Enterprises, if not, pm me and I'll forward the number when I get home...
Old 08-02-2005, 01:06 AM   #10 (permalink)
I recommend anyone who wants shocks to talk to Sam Jr from Stranoparts.com before throwing away money. If you want anything I would recommend talking to him. Of the people I would trust / believe are Pat, Sam & Jr and they all had good things to say about the non-Penske shocks in regards to the Z06.
Old 08-02-2005, 09:45 PM   #11 (permalink)
I think the only area you might get more "discussion" than shock tuners is engine builders...in both cases, you're working with individuals who have theories and ideas, based on experience, which leads them to their recommended set ups. I think this is definitely one of those circumstances where the "best" is that which fits your personal driving style and comfort level
Old 08-03-2005, 02:27 PM   #12 (permalink)
To be perfectly honest, big $$$ shocks are only going to buy you a few tenths improvement over the '04 shocks. There are quite a few nationally competitive drivers running on what are essentially stock shocks. If your driving talent isn't already close to nationally competitive .... then you're really just throwing money away.
If skill level is not a concern and the question is which shock is better, well ... how big is your wallet? I've heard great things about Ohlins and JRZ's .... but they're very pricey and there aren't a lot people running them. The Koni 28-series shocks are very nice .... have all the amenities of the Penskes but do not have the external reservoir (making install A LOT easier). But again, they are quite pricey.
I personally bought Ankeny 8100 series shocks and wasn't satisfied with them. I have since re-valved them through Penske and am much happier with them .... but that's not to say that they didn't work before. I just prefer the new setup. I guess that's the moral of my post .... a lot of it is driver dependent, so do some research before you bust out your credit card.
BTW, Pat Salerno's shock story, there are rumors abound about what actually happened ... so unless you heard it from his mouth, I would be very careful about what you take from it.
-Don
DKTZ06 is offline   Reply With Quote
Old 08-03-2005, 07:31 PM   #13 (permalink)
-Don
Don, FYI...this is for Braun's National car. If it'll get him 0.1 seconds...he'll take it.
Old 08-03-2005, 08:52 PM   #14 (permalink)
Oh, I see. Then what he wants is some Monroe adjustables from NTB.
Old 08-03-2005, 09:30 PM   #15 (permalink)
I think some 90/10's in front and some air adjustables in back would be about right for Matthew...help with weight transfer and all...
FS: Penske Shocks, Machine Faced Z06 Wheels, Race Tires DKTZ06 Member Sales - Parts & Cars 11 11-01-2005 08:24 PM
Want shocks.. Bilsteins or 04' shocks? 02BlackZ06 C5 Z06 - Pit Road 7 04-15-2005 03:56 PM
2004 shocks vs. Bilstein shocks Blkout C5 Z06 - Pit Road 2 07-19-2004 10:47 PM
04 shocks or T1 sachs shocks? zohhhsix C5 Z06 - Pit Road 8 06-07-2004 09:19 AM
FS: Penske race shocks Bowtieman Member Sales - Parts & Cars 2 02-06-2004 03:48 PM
