Old 01-12-2004, 10:45 AM   #1 (permalink)
Racing Seat Safety experts - seat modification question:
Hey Guys - I posted this over on CorvetteForum too, but I wanted to get as large a sample set as possible.
I have an OMP RS (www.ompusa.com) racing bucket mounted in my C5, with a Speedware motorsports bracket. It uses Recaro sliders and Sparco sidemounts. It works great, with one exception.
Due to the very tall leg side-bolsters, the upper/inner thigh bolster rubs on the center console to the left of the shifter. It is a tight enough fit that moving the seat forward and backwards at all is actually pretty difficult. As well, the cloth has rubbed through, and the fiberglass is starting to be exposed/rub a bit as well, and this is only in a few months of use/movement. (my car is codriven somewhat regularly with guys taller than me)
The seat cover is easily removable (lucky thing since my cat crapped on it once...argh!), and I was curious to see if it would be possible for me to remove some of the fiberglass of the seat without seriously compromising its structural integrity.
I believe that only a relatively small slice of material would need to be removed - maybe an index-finger sized slice at the right spot. But, I didn't know if removing material from the lip might cause undue stress-risers, weaknesses, or other problems. Plus, I don't know if the fiberglass shell is baked in some way, and I might end up with some nasty ragged fiberglass edges?
I ask because so far the seat is working well, but I want to replace some interior trim pieces at some point, and I don't want to replace that particular one if I'm just going to keep scraping it up with the seat. I may have to move to a different seat if there isn't a workable solution with this one.
Do any of you that race have experience with Caravaggio's seat? I always swap back and forth between my bucket seats and the race bucket for race days, so it'd only do duty as a racing seat. I've had a few Corbeau seats (Forza, A4) in other cars, and thought they where , and it looks like the nicer Recaros don't fit in the C5.
Any suggestions about the seat modification and other ideas are highly welcome.
Thanks for listening,
-Jake
JakeL is offline   Reply With Quote
Old 01-12-2004, 10:53 AM   #2 (permalink)
I don't know about your question with regards to triming your existing seats. Check out the following thread though, it has some info in other seats. I haven't had any troubles with the Caravaggio seats, though I have not had them for too long. If oyu have any questions about the Caravaggio's, let me know:
Any race seats fit the stock rails?
MySR71 is offline   Reply With Quote
Old 01-12-2004, 08:44 PM   #3 (permalink)
I highly doubt filing a 1/4 inch or so off of the lip of the thigh bolster would impact the integrity of the seat, but I really don't know, so this is just a guess.
Can you modify the bolt holes slightly and slide the front edge of the seat outwards (towards the door) an 1/8 inch or so?
FYI, I have a Cobra Suzuka seat mounted on special seat rails and it barely fits as well. Not much clearance at all between the center console and the thigh bolster.
Old 01-15-2004, 12:04 PM   #4 (permalink)
I'll bet you roll you windows up now!!!
Troy
P.S. How's the cat???
troyz is offline   Reply With Quote
Old 01-15-2004, 02:00 PM   #5 (permalink)
DJWorm's Avatar
You can modify the seat. You should be able to file sand or cut the excess off. The trick is to then camfer, smooth, and round the modification leaving NO sharp edges, dents, divots, dinks or depressions.
Old 01-15-2004, 02:19 PM   #6 (permalink)
Sounds good. That should make life with that seat easier...
-Jake
FS Sparco EVO seat and hardbar seat mount - $550 shipped jackmott Member Sales - Parts & Cars 11 06-06-2006 07:12 AM
Harness Bar and Seat belts using stock seat Phaster C5 Z06 - Pit Road 2 11-07-2005 05:46 AM
Installing new racing seats. Seat belt question 1701vette C5 Z06 - Pit Road 11 07-10-2005 02:00 PM
What does Carvaggio Race Seat weigh vs stock Z06 seat? Silver Bullet C5 Z06 - Pit Road 1 09-15-2004 02:31 PM
Any interest in bracket kit to mount EVO seat to manual seat track GNX Guy C5 Z06 - Grandstand 1 02-20-2004 10:49 AM
