Old 03-29-2006, 11:12 AM   #1 (permalink)
Rear wing..anyone tried and know how much it helped on road course
Rear wing..anyone try and know how much it helped on race course??
Was curious how much downforce,etc..
Old 03-29-2006, 11:23 AM   #2 (permalink)
PerforminNorman's Avatar
I'd check in with Lou at LG Motorsports. I think he/they have done extensive wind tunnel testing.
Come to the Z06 Fest!
Performin' Norman
Old 03-29-2006, 11:32 AM   #3 (permalink)
panzer's Avatar
I have the Caravaggio winglet on my car and I think it helps generate down force. However I don't think it really does anything except look nice at speeds below 120mph. I also have the canards on the front which I think are more helpfull than the winglet.
My car on the left and earlier incarnation of Tony3331's car
1985 BMW K100 m/c
panzer is online now   Reply With Quote
Old 03-29-2006, 11:35 AM   #4 (permalink)
MikesZ06's Avatar
My understanding is that it was invaluable!
At lunchtime, nobody had to get grass stains on their clothes because they were able to use the wing as sort of a 'picnic table'.
j/k with ya, bro
9.87 at 141mph
& 2007 Black C6 Z06
Old 03-29-2006, 11:42 AM   #5 (permalink)
j/k with ya, bro
That's just wrong. Funny, but wrong.
Old 03-29-2006, 11:42 AM   #6 (permalink)
panzer's Avatar
Yeah Mike...one of the design criteria is that the wing has to be strong enough to support the weight of a pony keg of beer and its tap...
Old 03-29-2006, 01:24 PM   #7 (permalink)
Be careful, this car already has too much lift in the front, so you don't want to "push" down on the rear without some downforce on the front.
I ran small Kinard (sp) front and rear - created about 100#'s of downforce (ea) at 100 MPH, just about perfect - car was a LOT more stable at 150+ - on the track.
LGM or MTI Racing in Marietta can hook you up.
Les
[sold] 02 QS Z06 383 c.i.
Old 03-29-2006, 03:19 PM   #8 (permalink)
Balancing rear with front downforce is crucial. In addition, you may need to change spring rates due to the additional downforce. Topspeed may also decrease due to the added drag. You also need to determine what wing angle works best for a given setup, track and track conditions. This is further influenced by tire choice and numerous other variables.
These are just a few examples of what needs to be taken into account. It isn't simply a matter of adding a rear wing and calling it good.
Old 03-29-2006, 03:50 PM   #9 (permalink)
Did someone call....
Sig by the Hillbilly!
Old 03-29-2006, 06:47 PM   #10 (permalink)
Yeah MTI was doing some testing recently.
Was just curious about front and rear setup
Old 03-29-2006, 08:44 PM   #11 (permalink)
Aero Balance is the key
I have received lots of flak about my adjustable boxwing, but I have balanced its downforce with a DIY Lexan splitter (see other posts re: DIY Lexan Splitter).
The boxwing is supported with: Lexan sheet to strengthen the hatchlid, and removable aluminum supports within the trunk bay that transmit the downforce directly to the frame.
What I have found is that on short twisty track courses, I can use both vanes of the wing and adjust them more agressively. But on longer tracks, say Road America, I remove the upper vane altogether as the bottom one smooths out the car just fine.
Old 03-29-2006, 11:37 PM   #12 (permalink)
SonOfaDragRacer's Avatar
Oh boy! Here we go...the wing thing...
NHRA S/C DRAGSTER - 7.70 to 9.90 index MPH avg. 180-200's
(Bump the lead) will run hi 6's low 200's
NO WING!!!!
U JUST DON'T NEED THE WING!
NHRA TAD DRAGSTER - 5.20 to 6.60 index MPH avg. 220-260MPH
(AFuel car "same class" has run 5.09 @ 280 MPH)
YOU NEED THE WING!
NHRA T/F DRAGSTER - 4.30 TO 5.20 index MPH avg. 300+
DEF. NEED THE WING - DRAGSTER IS UNSTABLE W/O IT!
With a street car I jus don't think you really need it..Sorry to use the "R" word but RICERS NEED IT...Image crap on a FWDR car..
If your Z is running High MPH and down into the low 8's high 7's or 6's then you can just reclassify it as a PROMOD!
But to each his own and you are talking abt. ROAD RACING...which is something I know hardly anything abt.
Car looks clean and nice...
Andy (SODR)
SIG by the BIGGEST, BADDEST MOFO with a broken down ride - GR8 WHITE
SonOfaDragRacer is offline   Reply With Quote
Old 03-30-2006, 08:50 AM   #13 (permalink)
The only answer is:
IT DEPENDS...
What speeds are you achieving?
At 150mph, there is approx. 50# of frontend lift on a stock Z06; put a wing on the back and create MORE rear downforce, you also INCREASE front lift by changing the attitude of the car, unless you run mega-rated springs, and even THOSE will settle some...
And aero changes can happen exponentially with MORE speed...
If you're gonna do the "wing thing", better think about the front as well. THAT was why we went with the full ACP front splitter/ rear wing(with adjustable height wickerbill) package, as it was developed with Corvette Racing's assistance and then wind tunnel-verified, and is a SYSTEM, not just random pieces...
Ricer be damned, it's ALL about "control"...or, lack of it...
With 600 rwhp, ours in capable of serious speed...best achieved with all four tires firmly planted...
PowerPro01 sez "STAY TUNED"................ GarettO's the SigGod!
"NOTHING Matters...until you CARE..." Bob Gibson
If RACING was EASY, they'd call it WINNING ! Anonymous
PowerPro01 is offline   Reply With Quote
Old 04-02-2006, 11:21 PM   #14 (permalink)
Send a message via AIM to robiferretti
agree with power pro, I am in the middle of the wing install on my car, (same wing Lou is running on his C6 GT car). I am just learning about the delicate balance that has to be made for everything to work in harmony.
I already have the front splitter from ACP and the side skirts, have to go back out to Kerry to get a custom under pannel built for the car because of the supercharger and radiator set up. Then I fine tune the LG coilovers I am running make sure I am at the best ride height to do some high speed driving. Doing the Bull Run rally this year as well as a few pocono events and the texas mile.
Lots of test and tune in my future though I am sure.
robiferretti is offline   Reply With Quote
Old 04-03-2006, 08:51 AM   #15 (permalink)
One of the critical factors, here, is the aero of the car is best kept with the 1/2" or so rake built into the standard body/suspension. That's why when lowering, you need to maintain that 1/2" or so tail-up attitude.
IF you add downforce to the car, it NEEDS to be equally distributed, front-to-rear-to-front, to maintain that ideal 1/2" REGARDLESS of speeds and their attendant changes to the car caused by speed-induced downforce (Or, if you mess up, the dreaded lift). And the greater the speed, the more importance this issue merits...
It's ALWAYS a good thing to have four tires well connected to the ground...
Low Profile Rear Wing jz06man C5 Z06 - Pit Road 12 07-05-2006 07:48 AM
Rear spoiler/wing. robz Racing 11 07-08-2004 11:48 AM
Wing for road racing ?????? ACI splitter speedpup C5 Z06 - Pit Road 1 01-08-2003 11:40 AM
Rear Wing zo6 tim C5 Z06 - Pit Road 2 07-09-2002 12:18 AM
Rear racing Wing zo6 tim C5 Z06 - Pit Road 3 06-19-2002 10:00 AM
