That description is correct. However, it's not good for the clutch to slip it nor is it good for the drivetrain to just "side step" it or "dump it". Although most people slip the clutch to some degree during slow speed driving such as around parking lots or in stop and go traffic, whenever you do so you are causing more wear on the clutch disc.
Higher performance clutches such as the Spec Stage 3, etc., will not slip at all, even if you wanted to. They are like an on/off switch.
