Single Layer or Dual Layer Jacket?
I have been worned numerous times that I need a fire jacket when racing the Z, so I figured its time to get one and as I was browsing the catalog, I noticed the jackets are offered in single layer or multi-layer. Is there a time restriction, where you would need the multi-layer? What kind of ET's can you run with only a single layer jacket? Both are SFI approved. Thanks in advance.
-Russ
Sig pic WAY too big
C5 Z06: Blk/Blk, 383 Stroker, Callies Rods/Crank, Diamond Pistons, Cartek 4X Heads, Cartek Custom Cam, Cartek Custom Fuel System, RC 74lb Injectors, Cartek Rear, Turbonetics Y2K-88 Turbo, Custom Chromoly 5Pt Rollbar, CCW Classics, ect...Pump Gas Street Terror...
C5 Coupe: Blk/Blk, Borla Cat-Back, CCW 505A's, FULLY loaded...Daily Driver...
